Car won't start
Old Nov 15, 2016 | 02:50 AM
Racur96's Avatar
Racur96
Default Car won't start
I've had my 13 ls3 manual 6 car torn down for a couple months now, got it all back together and it won't start. When I power it on the dash lights up after a few seconds, fuel gauge reads zero & says service fuel & a few other lights, security light stays on solid & the handheld obd2 scanner says no connection but it does power up when you plug scanner into obd2 port so it's not the cigar fuse. All fuses check good & ive checked grounds I could find. Would the ignition relay I've heard a few people discussing cause this issue?
Old Nov 15, 2016 | 04:20 AM
User Omega's Avatar
User Omega
Have you checked to see what the actual battery voltage is?
Old Nov 15, 2016 | 10:46 AM
Landru's Avatar
Landru
Battery must be load tested to rule it out, if good then dig deeper.
Old Nov 16, 2016 | 12:26 AM
Racur96's Avatar
Racur96
Load tested battery tonight, it was fine & replaced it with another one to be sure, checked all grounds to make sure they were all connected. Everything was good. Not sure where to go now
Old Nov 16, 2016 | 01:13 AM
Welker1's Avatar
Welker1
My next would be to take the starter out & have it tested .... good luck
Old Nov 16, 2016 | 01:58 AM
User Omega's Avatar
User Omega
You don't even have to take it out. Just jumper the excitation wire to positive. If it cranks then the problem is not the starter.
You want to jump the positive which is the one that has the terminal bent 90 degrees (in the pic it is straight for a different starter - middle terminal). Its easy to tell which big terminal wire it is because ground goes to the block. I found a pic from another post here. You take a wire from there to the small terminal. In this picture the small terminal shows it shaped funny. Should be easy to determine. Make sure that the car ignition is powered off. You don't want the car to actually start. You are just checking to see that when those two are jumped that it does or does not crank. If it does crank then you need to check continuity to ground. Then you will need someone to get into the car to see if the ignition switch wire is getting voltage. We can go from there if it does crank with the jumper and you need help with wiring or component diag.
Old Nov 16, 2016 | 02:11 AM
User Omega's Avatar
User Omega
This is C6Z diagram but I bet they are near identical.
Old Nov 16, 2016 | 02:39 AM
Racur96's Avatar
Racur96
This isn't my starter but a good pic of the same starter. Mine has 2 wires up top where the stud would be( it's broken off of this starter in pic) jump it over to the right side where the little wire that clips in goes?
Old Nov 16, 2016 | 02:48 AM
User Omega's Avatar
User Omega
Yes. + to what should be a purple wire. Unplug connector and wire goes in. If only sparks come off of it or you for sure have a good connection and it does not crank the starter is bad. Given the positive and grounds are good.
Old Nov 16, 2016 | 02:51 AM
User Omega's Avatar
User Omega
Oh and do keep in mind that if you ground a wire from positive it is probably going to get stuck and instantly melt the coating off of the jumper, burning you and anything else it comes into contact with.
Old Nov 16, 2016 | 02:57 AM
Racur96's Avatar
Racur96
Ok I'll check that , my wire isn't purple but it is the same wire by the diagram. Where is the crank relay right above starter diagram located? In the fuse box? I haven't swapped it or anything just tested the mini fuses.
Old Nov 16, 2016 | 03:01 AM
User Omega's Avatar
User Omega
I'm not positive on the base cars. Refer to user manual or pop off the covers and see what they say. You could jump the relay and achieve nearly the same thing. Doing it at the starter just eliminates everything from the equation.
Old Nov 16, 2016 | 10:36 AM
turboed350z's Avatar
turboed350z
I recentlyhad this same problem. Turns out, one of my wires were burnt through and needed to be replaced. So you might want to check the wires from the battery leading to the starter, behind the headers. Mine were burnt causing issues.
Old Nov 16, 2016 | 10:47 AM
mrk1957's Avatar
mrk1957
From your original post, it looks like you have something else going on other than the starter. Before you took your car apart I'm guessing it was okay? What did you do to your car while it was down? You might want to backtrack and recheck your work. I've been around to long to believe in coincedences and usually find it's something I knocked loose or left unplugged.
Old Nov 16, 2016 | 08:00 PM
Racur96's Avatar
Racur96
Hi I jumped the starter from hot cable over to connector and starter spun over as it should. I had the engine out, I'm sure it something I've had loose as it did work fine before but I've back tracked everything I can think of.
Old Nov 17, 2016 | 12:03 PM
User Omega's Avatar
User Omega
The fact that this is combined with other issues really makes me think you are just overlooking something silly since you've recently had things apart and it hasn't worked since.
If you unplugged any main harness wiring go back and check the connections. Pull the plugs apart again and look inside. You didn't put any dielectric grease in any of them did you? Maybe you have a recessed pin or something in there. Make sure that if you removed any power or ground wires that you go back and inspect them closely.
Old Nov 17, 2016 | 12:04 PM
User Omega's Avatar
User Omega
Where are you located?
To Car won't start
Old Nov 17, 2016 | 01:59 PM
mrk1957's Avatar
mrk1957
Yes, keep checking, I'm sure you'll find something disconnected or whatever. I've been there done that a few times. Maybe step away from it for awhile and go back and try again. Take your time.
Old Nov 18, 2016 | 01:38 AM
Racur96's Avatar
Racur96
I didn't grease any connections, I've checked grounds & re cleaned them, block has continuity 0f .2-.4 at those spots & grounds on frame rail are all 2.2-2.4. I did notice tonight that the drivers window won't go up or down but the pass works fine using the controls from drivers door?
Old Nov 18, 2016 | 07:09 AM
User Omega's Avatar
User Omega
I really don't know enough beyond this point to be helpful. It really does sound like a ground problem with everything being so wacky. That or maybe the EBCM has issues???
I know the battery cable ends like to be clean and tight. Maybe check those out?
