stupid P2135 code
Ive tried to figure out at what point it throws it but I've come to the conclusion it doesn't matter what I'm doing its just random. it will throw it during normal acceleration, WOT or even at stop lights when I'm not touching the throttle. I've replaced the pedal assembly with a brand new one and it threw the code within 5 miles. According to the previous owner the throttle body was replaced and it still did it. the pcm has been replaced as well. my tuner checked continuity on the wires with no luck on anything standing out. the dealership spliced on a new connector in the harness at the throttle body which didn't help either. does anyone have any clue at what my next option is? like i said i can't even enjoy my car anymore and it sucks
from all the other threads I've read everyone seems to have luck with changing the TB or the pedal but I'm at a loss now… thanks
2005 c6 z51
There is a bulletin for that code PIP3089B. Possible bad terminal crimps and/or broken wire inside of the insulation at the TB connector. With the car running try grabbing and moving the TB connector and harness and see if you can get the code to set.
#PIP3089B: SES Light And Reduced Engine Power DTC P0120 P0220 P1516 P2135 - keywords accelerator actuator APP blade body connector connection DTC L33 L59 LH6 LR4 LM7 LS1 LS2 LQ4 LQ9 module position reduce sensor - (Oct 31, 2006)
Subject: SES Light and Reduced Engine Power DTC P0120 P0220 P1516 P2135
Models: 2004-2006 Buick Rainer
2005-2006 Cadillac CTS-V
2003-2006 Cadillac Escalade
2003-2006 Chevrolet Avalanche, Corvette, Express, Monte Carlo, Silverado, SSR, Suburban, Tahoe, Trailblazer
2003-2006 GMC Envoy, Savana, Sierra, Yukon
2003-2006 Hummer H2
2005-2006 Pontiac GTO
Equipped with a 4.8 5.3 6.0 or 7.0 V-8 Engine
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
A vehicle may be brought into the dealer for a reduced power message, and DTCs P0120, P0220, P1516, P2101, or P2135.
The Throttle Actuator Control (TAC) / throttle body type trouble codes, may be caused by a loose wiring crimp at the throttle body connector, or a broken throttle body circuit.
Recommendation/Instructions:
Complete the current SI diagnostics for any symptoms or trouble codes found. If a intermittent T/P or TAC module type code is occurring complete the inspections below.
1. Inspect all related throttle body terminals for a loose wiring crimp. The loose crimp may be difficult to find, and the poor connection will be between the terminal and the copper strands of the wire. Wiggle test the individual throttle body circuits to see if the concern can be duplicated.
2. Inspect the related circuits for broken wires inside the insulation. The outer wire insulation may look fine, but the internal copper strands may be partially broken. Breaks in the wires usually occur within 1 to 4 inches of the throttle body connector. Wiggle testing may also induce a trouble code to set.
3. On C/K trucks complete SI procedures for voltage drop on grounds G103 and G104. Grounds G103 or G104 may be loose or corroded.
If a terminal crimp or a broken wire has been found, repair or replace only the circuits involved. There is a throttle body pigtail connector available through GMSPO, but installing this pigtail connector may cause other intermittent TAC module/TP codes at a later date. If this pigtail must be used, please follow the SI procedures for Splicing Copper Wire Using Splice Sleeves. (the proper Kent-Moore crimping tool must be used for this repair)
__________________
David - 07 LMB A6 1LT Z51 QX1 - SOLD
www.reichertwoodstock.com/
GM VIN reports, build dates and recall info - PM me with your email addy and VIN (98 and newer only)!
GMautotech is offline Report Post
2003-2006 Hummer H2
Condition/Concern:
__________________
If that looks okay, I'd move on to looking for a wiring problem with the other signals.
If you have no test equipment, no Tech 2, but you can clear the code, clear it. Start the engine, let it warm up. Go to the small U-shaped harness exiting the Throttle Body. Wiggle it, move it around, see if you can cause the code to come back. There is one signal wire in that sharp bend that breaks under strain and is one cause of this MIL. And more so in early C6s.
If you've explored this common failure and the TB has been replaced, there is only one more component not mentioned and a longer shot, the throttle pedal sender unit.
Actually, there is a critical "handshake" signal - TPS to ECM (idle control circuit) that, if lost, the ECM is not going to be able to follow the idle RPM table.
Based on the replies, it sounds like you have a good starting point to try and correct teh issue.
Don't get me wrong - I'm sorry for your predicament - but the fix here is to first diagnose the specific problem. Replacing everything is way too expensive and time-consuming.
I have a quick question what is the CPM I just got a corvette about 3 months ago and I started having the same problem.
