Cerakote my Headers
Old Dec 7, 2016 | 04:35 PM
choppychop's Avatar
choppychop
Default Cerakote my Headers
Cerakote materials came in today. Instructions say to blast parts to be coated. Does anyone know if this is mandatory? I got the C3 coating good to 1700 degrees.
Anyone done this yet?
Old Dec 7, 2016 | 05:59 PM
HK770's Avatar
HK770
You suppose the people who made Cerakote knows anything about it?
All else fails read instructions or just look at pictures .....LOL
luck
Old Dec 7, 2016 | 06:20 PM
449er's Avatar
449er
CF Community Team
You are going to coat your own headers?
Old Dec 7, 2016 | 06:44 PM
CaliVetter's Avatar
CaliVetter
I have done this many, many times and posted here about a month ago about the process. You will need to either blast or hand sand the headers to get them smooth. do not touch them with bare hands afterwards and clean them thoroughly with Acetone afterwards. Get them as smooth as possible and as clean as possible. Apply ONE thin coat of Cerakote NO MORE. This is one of those times that more really is not better. It is not necessary to heat them if you got air dry Cerakote. If you did not then bake them in the oven and install them. I usually get the Cerakote good to 2300-2500 degrees but the headers aren't going to get to 1700 temps either. This is the best thing I did to my headers. NEVER have they rusted, chipped, or lost the coating after applying Cerakote. I can not stress this enough..USE A RESPIRATOR when spraying them. Cerakote is some seriously nasty stuff that you do not want in your lungs
Old Dec 7, 2016 | 07:19 PM
choppychop's Avatar
choppychop
Thx, taking them to get blasted tomorrow, and yes I searched FAQ for details and found none...
Appreciate the responses, I'll try to post results.
Old Dec 7, 2016 | 07:30 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
Cerakote is used on refinishing firearms, but I have never heard of it used on a set of headers.
Are you sure this is a good idea?
Old Dec 7, 2016 | 07:36 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
i remember reading the thread---well written!
https://www.corvetteforum.com/forums...nd-rotors.html
Old Dec 7, 2016 | 07:39 PM
CaliVetter's Avatar
CaliVetter
I'm positive.
Old Dec 7, 2016 | 07:57 PM
choppychop's Avatar
choppychop
Yes, excellent. Thanks
I'm also going to do my intake cover after getting intake ported... if the headers turn out well... appreciate the link.
Old Dec 7, 2016 | 10:10 PM
CaliVetter's Avatar
CaliVetter
Don't forget to take the U clamps to be sandblasted and to also Cerakote them as well. I always Cerakote from the headers all the way to the mufflers and then the axle back to the tips and all hardware/U clamps. All my exhausts are welded front to back but some like the U clamps for easy change. Regardless, do everything you can minus the cats and mufflers all the way to the exhaust tips
Old Dec 8, 2016 | 11:26 AM
hydrasport's Avatar
hydrasport
Cerakote makes a coating specifically for headers. Don't buy the cerakote for firearms. Check their website for header coatings.
To Cerakote my Headers
