05 z51
Old Dec 10, 2016 | 01:17 AM
Smokeysvette's Avatar
Smokeysvette
Default 05 z51
The car I just bought (05 C6 LS2 6-speed) is supposed to be a Z-51 car but how can I tell that it really is one. I'm familiar to the C4's but this car is in a complete different league than my other two C-4's I have now. This car is great and love it but the only thing I wish they carried over was the wrap-around cockpit dash of the later c4's. Other than that this car is aw-sum! But again with certainty,How can i tell this is a Z-51 car?
Old Dec 10, 2016 | 01:22 AM
Red Devil Z51's Avatar
Red Devil Z51
Look on the inside of the glove box door on the far left side as u sit in the passenger seat just past to the left end box itself will be a sticker it lists all the option on a car when it was delivered. Look for the code z51 if its there it is a z51 if no code it isn't
Old Dec 10, 2016 | 01:39 AM
Smokeysvette
OK I'll have a look. duh I should have thought of that since my 92's have their RPO'S there too. I have a Corvette black book but it's too old to check and see what all RPO's this car has. Anyone have a RPO list for the 05's?
Old Dec 10, 2016 | 02:12 AM
z06Don's Avatar
z06Don
drilled rotors as well is another easy tell
Old Dec 10, 2016 | 05:59 AM
01Z06 Black's Avatar
01Z06 Black
St. Jude Donor '08
You will find them here.
http://www.c6registry.com/facts/2005.htm
Old Dec 10, 2016 | 09:36 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Unless someone replaced the rotors.
Old Dec 10, 2016 | 11:24 AM
Dave S's Avatar
Dave S
Retired & lovin' it!
I've also got an '05 Z51 & as the OP noted, the code is on the sticker in the glove box. And the fact that there may be drilled rotors installed is no positive evidence.....they may be aftermarket.
Old Dec 10, 2016 | 02:46 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Enjoy your new ride and if you need the owners manual on the web, just click below.
http://www.c6registry.com/Technical/manuals/2005OM.pdf
Old Dec 12, 2016 | 10:02 PM
Smokeysvette
The car is not with me for a couple of days because it's having the harmonic balancer replaced because of the problem they had with them. I bought it only if they agreed to replace it regardless "if" it looks fine. So I won't see the glove box lid RPO's until I get it back. But yes it does have the drilled rotors as I did notice them. They guessing are probably stock on the car too. I'm thinking that as this car has not been modified in any way that I can see.
I Also ordered the skip shift eliminator and the Column Lock Delete wire loom to so I won't have that problem either. Just tiring to cross some of my I's and T's.
So far this car is a blast to drive and worlds different than my C-4's that I have now.These C6's are very new to me so Ill be asking lots of question's too.
Thanks for all the help!
To 05 z51
