Driver Door Will Not Open
Thanks.....
Thanks.....
Take it apart and clean it. If that is not the solution, you may need a new door latch assembly.
From the Service manual
Door Latch Inoperative from Interior Door Handle Switch
1. Ignition OFF, disconnect the harness connector at the inoperative interior door handle switch.
2. Test for less than 1.0 ohm of resistance between the ground circuit terminal A and ground. If greater than the specified range, test the ground circuit for an open/high resistance.
3. Ignition ON, verify the appropriate door control module scan tool interior door handle switch parameter is INACTIVE. If not the specified value, test the signal circuit terminal C for a short to ground. If the circuit tests normal, replace the appropriate door control module.
4. Verify the appropriate RCDLR scan tool interior door handle switch parameter is INACTIVE. If not the specified value, test the signal circuit terminal B for a short to ground. If the circuit tests normal, replace the RCDLR.
5. Install a 3-A fused jumper wire between the signal circuit terminal C and ground terminal A. Verify the appropriate door control module scan tool interior door handle switch parameter is ACTIVE. If not the specified value, test the signal circuit terminal C for a short to voltage or an open/high resistance. If the circuit tests normal, replace the appropriate door control module.
6. Install a 3-A fused jumper wire between the signal circuit terminal B and ground terminal A. Verify the RCDLR scan tool interior door handle switch parameter is ACTIVE.
If not the specified value, test the signal circuit terminal B for a short to voltage or an open/high resistance. If the circuit tests normal, replace the RCDLR.
7. If all circuits test normal, test or replace the appropriate interior door handle switch.
It has troubleshooting guides, Operation of all the circuits including schematic, diagrams and component views.
I would add it on here, but the file is too large to attach to a post.
It may help determine the cause of the issues.
Thanks.....
It may help determine the cause of the issues.[/QUOTE
please send would appreciate
