Homelink buttons
Homelink buttons
I found the RPO codes thanks to Forum members. I see that I have the home link system. The manual shows the 3 buttons and lights but not the location. Where are the buttons located on a 2009 vert? Thanks
I found the buttons just to dark in the garage and they blend in with the visor. Thats my story and sticking to it LOL.
When I got my Corvette the receiver wouldn't acknowledge the transmitter. I had to buy a module ~$35 for it to work. Now I have one add on module for the 05 Ford PU and one for the Corvette. The 2014 Flex worked with the door opener receiver. Hopefully I won't have to get more for cars down the road. Running out of room to piggyback them up there..!!
Edit.... When I got mine to work I cleared all codes and in fact used the center button. Also required 2 people to press the buttons at the same time! Not one then the other. Hope this helps
Douglas
Douglas
Steve
I couldn't program my '07 at first (have the homelink); had to erase all buttons. Then it was a two-step process - - I had to program it to recognize the original transmitter for my newer Liftmaster opener, then program the homelink button to the opener. It works great now.
Steve
Steve
Douglas
Douglas
You need to look up the specific opener you have. Dirrerent openers require different repeaters "modules" for them to work with the specific type of built in car opener. In my case it was much easier and cheaper to just go buy additional remote openers.
I don't mind purchasing an additional repeater, I'd like to be able to use the home link if possible, I'm just not sure where to buy a repeater?
Just moved into new house with my '05. Unable to get Genie remote and home link to sync. Had no problem connecting to new Genie unit last year at old house. ?????
https://secure.homelink.com/homelink...ter-kit-detail
weathermaker (01-08-2017)
Homelink and LearCar2You Do Not speak to each other very well. My 06 Z has Homelink, my new garage door opener is Lear. Sometimes, it takes many pushes of the visor buttons to get the door to go down when leaving, sometimes, it just won't work. I did not buy a separate module, maybe that's what I need.
Well I found out I have a new opener with the Security+ 2.0, so I think I'm going to try this repeater/bridge from homelink:
Hope you get it working.
Most of the newer openers have MyQ technology which means that are able to be controlled with your phone. Many of then come with the gateway in the opener and others you have to add the gate way for the wifi signal. Install the app on your phone and use it.
I just prefer to use the clip on control that came with the opener.
For those of you asking where to get the repeater module, I got both repeaters from Liftmasteer
For the Homelink repeater:
https://www.liftmaster.com/for-homes...elinkbridgekit
For the Lear, Car2U repeater:
https://www.liftmaster.com/for-homes...del-car2u-rptr
They may be available via Amazon as well.
Just wanted to give an updated.... I revived my Homelink repeater today, took 5min to install and it works PERFECTLY, only cost $28/shipped well worth it IMO!
