climate control
Old Dec 27, 2016 | 06:03 PM
jlbsam's Avatar
jlbsam
Default climate control
Hi all, hope everyone had a nice Christmas! I haven't posted anything in awhile, cuz my Vette has never really had any issues-until today. It was parked for a couple of weeks, started right up, but the outside temp showing on the climate control panel is stuck on 55F, even though in sunny So. Ca. its over 70. anyone have a fix for this? Thanks!
Old Dec 27, 2016 | 06:10 PM
Bruze's Avatar
Bruze
Mine has done that a couple of times, but corrected itself after 10 minutes or so of driving.
Old Dec 27, 2016 | 06:12 PM
DLove25's Avatar
DLove25
2nd Gear
Default Climate control
Had the same issue with my C6. After a couple of drive cycles, it cleared itself up. Give it a day or 2 and hopefully you'll have the same result.
Old Dec 27, 2016 | 06:31 PM
Elizabeth City Vette's Avatar
You can also manually reset the sensor by pressing Rear Defrost, Front Defog and Fan Speed Increase button at the same time. That will force an update of the temperature display.
Old Dec 27, 2016 | 08:07 PM
Red08's Avatar
Red08
That's not unusual. It is common to sometimes take several minutes to adjust to the actual outside temp. I've noticed it with my 2016 Silverado a few times too. I don't worry about it. It eventually catches up.
Old Jan 3, 2017 | 06:27 AM
dsherman's Avatar
dsherman
I actually had this issue on my 08 C6. One day it read 32' and stayed there Throughout the day no change, 2 days later tried the 3 finger salute. Which did make the display go to day time temperature display. But only to have it revert back to being stuck the next day. So while the outside temp was barely 60 I manually turned on the AC and max cold. I took some time but the system went to vent for a bit then onto full AC. Has been working ever since.
dsherman
Old Jan 3, 2017 | 02:23 PM
Mad*Max's Avatar
Mad*Max
this has been happening in my car since the day I bought it ten years ago, my other two GM cars never experience this "issue"
To climate control
