Thanks, the part number does come up under google. Do you know if it is the complete setup with insulator? The descriptions that come up only state the carpet assembly.
I am looking for the complete heat pad and carpet.
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Heat pad? What heat pad? Are you looking for a complete carpet set for the car or just the carpets that clip down on each side on top of the base carpet? Again, Gene at Cultrag is the person that can get you what you need.
I don't know if anything extra is included, but the pads that run along the tunnel have part numbers 15298985 (left) and 15298984 (right).
