isimple bluetooth help
Old Feb 1, 2017 | 10:32 PM
moldyviolinist's Avatar
moldyviolinist
Default isimple bluetooth help
Hi,
I just bought a 2008 Corvette with NAV, it came with the isimple bluetooth adapter thing. Not sure the model number but it has bluetooth, aux, reset button.
I cannot play any music. I don't care about bluetooth, i just plan to use aux cable, but the radio seems to be stuck in XM Preview?? The only time I can play music is for a few seconds after I hit the reset button. Then the screen shows dev init and music will play over aux, but I have tried everything, doesn't seem to be a way to set it to do that all the time.
Someone help?? I have looked through the diy install thread of this module, but it didn't help, and the manuals i can find online are for non-nav...
Old Feb 2, 2017 | 12:45 AM
Cauhauna's Avatar
Cauhauna
i have this too. switch away from radio (to nav, for instance), then switch to either xm1 or xm2 - depends on which it was installed on. try both. once there, hit the "seek" button and you should see yourself scrolling through inputs where the name of the radio station would normally be. (AUX1, AUX2, BT) etc. do this until you land on Aux 1 or Aux 2 (try both to see which it is isntalled on).
That should do it.
Old Feb 2, 2017 | 10:35 AM
moldyviolinist
Ah OK thanks, i will give that a try when i get home, i never switched out of XM mode
Old Feb 6, 2017 | 11:39 PM
Cauhauna's Avatar
Cauhauna
did it work?
Old Feb 7, 2017 | 12:10 AM
moldyviolinist
Originally Posted by Cauhauna
did it work?
Yes, that worked perfectly, thank you!
To isimple bluetooth help
