I have a 2005 corvette and check engine light came on with P0016 - Crankshaft Position - Camshaft Position Correlation and p0335 crankshaft position sensor ...anyone think they might be related due to a bad sensor??? car runs fine it just takes a while to turn over
the 2 codes are related and quite often will show up at same time.sometimes a crank relearn procedure may correct the issue.the long crank to start quite often an issue with cam position sensor.any work done on car recently?check harness to cam position sensor.car will run with cam position sensor not functioning but I don't think it will when crank position sensor is bad
Yea i just changed the fuel level sensors on it a few days ago
Sounds like you need a new crank position sensor, soon it won't start at all.
Yeah real soon it didn't want to start this morning disconnected the battery and connected it back on and it started up so i ordered a new sensor this morning I hope it correct the problem
