HUD Control Switch backlight not working
Old Feb 2, 2017 | 01:14 AM
mlicker's Avatar
mlicker
Default HUD Control Switch backlight not working
Don't the HUD control switches backlight?
I don't drive much at night and took mine out for a cruise (1st nice day in a long while). The swithces on the left side do not light up. Anyone...??
Old Feb 2, 2017 | 04:02 AM
User Omega's Avatar
User Omega
Yes they should light up.
This is not my image but you can see them lit up in this photo.
Old Feb 2, 2017 | 06:58 AM
Dcasole's Avatar
Dcasole
If your handy with a soldering gun you can replace the bulbs , its easy
Dont have the link handy but search my posts , i did a write up about replacing them
Dave
Old Feb 2, 2017 | 11:28 AM
mlicker's Avatar
mlicker
Dave
Awesome, thanks Dave.
p.s. I'm familiar with you're neck of the woods. My 85 yo mom lives in Winder. I fly out to visit every October.
Old Feb 2, 2017 | 11:30 AM
Dcasole's Avatar
Dcasole
that is awesome... next town over from me
If u need help just email me at dcasole at comcast.net
Dave
Old Feb 2, 2017 | 12:13 PM
extrapilot's Avatar
extrapilot
Every light doesn't work? Usually the bulbs go out one at a time, thinking the plug connector is a issue perhaps.
Old Feb 2, 2017 | 12:54 PM
mlicker's Avatar
mlicker
You might be on to something. I'm home from work with the flu, but think I can muster enough energy to check this out right quick.
Thanks for this....
Old Feb 2, 2017 | 01:17 PM
mlicker's Avatar
mlicker
Got the bezel off and the connector is tighter than all get out. I'll need to gather some more strength to go further. Another day. At least I'm 20% through the task. I'll order the (10) 7219 bulbs from Amazon and have them handy regardless.
Old Feb 11, 2017 | 01:39 PM
mlicker's Avatar
mlicker
I was able to buy an entire new HUD switch assembly, very affordable, from Cultrag Performance. I removed the old switch and installed the new switch. Turned on my lights and still nothing. The HUD works fine, but the backlight on the switches does not. The failure must be in the harness or connector. Is there a section of harness that is common to cars with HUD that is easily accessible, or is it part of the entire dash harness..? I also noticed one pin on the removed switch is missing, if all 8 pins are supposed to be intact on the switch connector. Any electrical guys on here with ideas...??
Old Feb 13, 2017 | 09:32 AM
mlicker's Avatar
mlicker
Anyone.. ^^ .??
Old Feb 13, 2017 | 09:55 AM
4SUMERZ's Avatar
4SUMERZ
Anyone.. ^^ .??
Have you checked the Cluster /HUD 15 A fuse in the passenger footwell?
see the schematic for more info and wiring
Old Feb 13, 2017 | 09:59 AM
mlicker's Avatar
mlicker
The HUD displays fine, it's just the switch backlight. I will check the fuse just the same. I hope it's that simple.
Thanks for your reply and providing the schematic. That's AWESOME .... !!
Old Feb 13, 2017 | 11:44 PM
User Omega's Avatar
User Omega
Have you checked the lighting circuit on this schematic?
Old Feb 14, 2017 | 09:44 AM
mlicker's Avatar
mlicker
Can you elaborate more? I'm not real smart electrically. The schematic above shows the Switch and the HUDisplay on the same circuit, same fuse no? If the HUD works and the switch illumination doesn't, I'd think its in the harness and not the fuse (fuse above shows to be common to both switch and HUDisplay. I'm open to all suggestions at this point.
TIA
Mark
Old Feb 14, 2017 | 11:55 AM
jaki30's Avatar
jaki30
Default HUD is separate
TIA
Mark
What is shown is the illumination of the switches. Are the HUD adjustment switches lit? What about the MODE switch?
If they are all out I would check either the Jumper from the C 109 connector or the Ground wire. Loss of either one would knock out the illumination of those bulbs. The last item would be the fuse, but, it looks like the HUD and Cluster are powered off the same fuse.
Old Feb 14, 2017 | 12:12 PM
mlicker's Avatar
mlicker
Yes, all switches are out. The HUD works just fine. Only the bank of switches are not illuminating. Mode and all. Might not be worth digging too deep into this with my limited electrical skills. If there was an easily accessible ground point to check, that would be easy enough. The schematch really doesn't define where that ground is from what I can tell. Again, I'm limired electrically.
Old Feb 14, 2017 | 05:17 PM
User Omega's Avatar
User Omega
Check continuity on the plug itself to see if the ground is good.
Old Feb 14, 2017 | 05:28 PM
jaki30's Avatar
jaki30
Default New switch removed
If you were able to install the new switch you had to have access to the connector. You can measure the ground terminal to chassis ground with an ohm meter. Also, you measure the voltage at pins 5 and/or E with the lights on. You can use a cheap digital meter from harbor freight.
Old Feb 14, 2017 | 07:27 PM
4SUMERZ's Avatar
4SUMERZ
The schematic shows the Instrument Panel Cluster ground point for the illumination circuits shown in the schematic. The Ground point (G201) is at the base of the Left A pillar. The ground G 201 is used by many of the interior circuits, door switches, etc, so chances are that is OK. If you can check the connector pins as described above, you can see if the connections are OK, including the ground.
Hope that helps, and Good Luck
To HUD Control Switch backlight not working
