2007 navigation system question
Old Mar 11, 2017 | 02:34 PM
2007c6bob's Avatar
2007c6bob
3rd Gear
Default 2007 navigation system question
Used the nav system for first time in about 5 yrs and can't recall how to shut it down. Manual does not seem to go into shut down. Can anyone advise. Tks 2007c6bob
Old Mar 11, 2017 | 03:02 PM
EVRose's Avatar
EVRose
You mean just turn it off? Push the volume ****.
Old Mar 11, 2017 | 04:53 PM
2007c6bob's Avatar
2007c6bob
3rd Gear
Thanks for the reply - I thought I tried that but the radio just turned on and off but I'll try again...... The radio and gps are all linked together on the dash.
Old Mar 11, 2017 | 05:34 PM
EVRose's Avatar
EVRose
What exactly are you trying to do? Cancel nav is
Menu-route options-cancel guidance.
Old Mar 11, 2017 | 06:27 PM
HBsurfer's Avatar
HBsurfer
And if you just want to get your radio screen back, press the 'srce' button to the left of the screen (just above the 'nav' button)
Old Mar 11, 2017 | 06:46 PM
65GGvert's Avatar
65GGvert
If you touch the source button first to display the radio, then push the power button, it will turn off and display the Corvette emblem screen.
Old Mar 12, 2017 | 11:54 AM
bassman50's Avatar
bassman50
Did you receive a NAV manual when you purchased your car? If not, there is a 2008 (radios are basically the same) NAV manual you can download on-line. There is no information on the NAV system in the regular owners manual. Hope this helps.
Steve
Old Mar 12, 2017 | 11:59 AM
extrapilot's Avatar
extrapilot
Steve
Here's the manual;
http://www.theredlion.us/2008corvette_nav.pdf
Also some tech tips and video instructions that should come in handy;
http://www.theredlion.us/Tech%20tips2.htm
Old Mar 12, 2017 | 12:13 PM
RobLo's Avatar
RobLo
Old Oct 21, 2023 | 11:58 AM
Fatbloke-Dim's Avatar
Fatbloke-Dim
Here is what I have just done,and it worked,got me right back to the corvette badge. Switch over to a radio function from nav,by pressing the radio on/off ****,then press the square button in the vertical line of about four on the left that reads like sage,or sace,then press the radio on/off **** again.job done,cool vette logo back on !
Old Oct 22, 2023 | 05:59 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
If all else fails, reading the manual helps!
Tom
Old Oct 22, 2023 | 06:11 PM
Vette_DD's Avatar
Vette_DD
Tom
OP says he read the manual, but it didn't tell him how to shut it off.
Maybe you didn't read it all.
Old Oct 23, 2023 | 04:59 AM
Fatbloke-Dim
Yep , manual has nothing to say on it. Maybe a case of W.T.F.M. as in WRITE it !!
To 2007 navigation system question
