Reverse paddle shift
Old Mar 16, 2017 | 06:18 PM
Giamanut's Avatar
Giamanut
Default Reverse paddle shift
Anyone know if it is possible to reverse the up/downshift function on a paddle? would like to make my right paddle function opposite.
Old Mar 16, 2017 | 06:41 PM
acheman8's Avatar
acheman8
There is a way. You have to pull of and re-wire the paddles. There are a couple of threads about it on the forum. Do a Google search and it should point you to the right thread.
Old Mar 16, 2017 | 06:49 PM
Mike Green9's Avatar
Mike Green9
This may be of some help:
http://www.bratten.org/c6/Paddle/Index.html
M...
Old Mar 16, 2017 | 07:08 PM
Giamanut's Avatar
Giamanut
Thanks gents exactly what i thought! I have down shifted by mistake for the last time!
Old Mar 16, 2017 | 07:26 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
I did it, but I simply cut the two wiresdid a pressure splice connection and a heat srink insulator. I also changed the paddles to custon made aluminum paddles.
Old Mar 16, 2017 | 08:31 PM
Lew Shaw's Avatar
Lew Shaw
I did it to my 2010 GS and in my opinion, it's the best free mod there is to be had!
Lew Shaw
M...
Old Mar 16, 2017 | 08:47 PM
Giamanut's Avatar
Giamanut
Old Mar 17, 2017 | 09:52 AM
Torquem's Avatar
Torquem
I much prefer the F1 Shift module as it keeps the function of each paddle the same regardless if you are pressing or pulling it. If you never press the paddles, then it won't really matter.
To Reverse paddle shift
