A Leak Question?
Old Mar 30, 2017 | 08:43 AM
HMannini's Avatar
HMannini
Cruise-In X Veteran
St. Jude Donor '09
Default A Leak Question?
January I had to have my radiator support bracket replaced and since then after I take the car out I find what seems to be Dex Cool underneath the driver side aft of the tire. Sometimes it's a good stream after a long drive and in the photo it's just a couple of dots after a short drive. I've been to two different shops and they tell me they can't find anything wrong but it keeps popping up? I thought it might be overflow from the tank but it should have been gone by now since I haven't topped it off.........anyone else have this?
2012 GS LS3 No Mods
Old Mar 30, 2017 | 10:19 AM
extrapilot's Avatar
extrapilot
Not to sure coolant lines are routed in the above area, although there is the washer reservoir located right behind the left front wheel, could it be this?
Old Mar 30, 2017 | 10:52 AM
HMannini's Avatar
HMannini
Cruise-In X Veteran
St. Jude Donor '09
The washer liquid is blue this is pink and a little oily...........
Old Mar 30, 2017 | 11:09 AM
EVILFACE's Avatar
EVILFACE
clean the area and see if it leaks again and not something that was picked up during the drive.
To A Leak Question?
