engine light...catalytic problems...
Old Apr 4, 2017 | 04:29 PM
buckmeister2's Avatar
buckmeister2
Default engine light...catalytic problems...
Folks,
My 2008 base C6 with 101,000 miles on it is showing an engine light. I had Oreilly's check it out, and it came up "catalyst system below threshold, bank 1". My car has one converter on each side.
Is it likely the converter, or possibly a sensor? I am getting ready to put a z06 system on the car, so if it is the converter, I don't want to spend the money to fix that, as it will soon be replaced. If it is a sensor, it obviously needs to to be replaced. If it is a sensor, how do I know if it is the front or rear sensor?
I am assuming the "bank 1" is driver side...correct? Coincidentally, the driver side downpipe on the z06 system I will be installing needs a new converter, so that has to be taken care of before I do the switch.
So, any ideas on what might be the root cause?
Old Apr 4, 2017 | 04:45 PM
CadVette's Avatar
CadVette
More than likely it is the catalytic converter. I believe the oxygen sensors give a different code. To verify it is the cat you can unbolt the exhaust from the manifold on the drivers side. Start the motor and wait to see if the engine light goes out. Since you are getting into the exhaust this far you might as well replace the system with the ZO6 type. Magnaflow makes high flow cats for a resasonable price.
schizcat's Avatar
schizcat
Could be either. You can wait until after you put the Z06 system on to see if that fixes it. Same thing happened to me right before I put my long tubes on. Since I was doing a header swap and my inspection was coming up, I paid a tuner $25 to "turn them off" to pass inspection.
Old Apr 4, 2017 | 05:01 PM
buckmeister2
schiz..I was thinking about turning them off, too, but won't that show up on the readout? Our state does a visual and an OBD check. Isn't the turned off sensor going to signal on the OBD port?
Jim
Old Apr 4, 2017 | 05:03 PM
buckmeister2
When you say "Magnaflow makes high flow cats for a resasonable price.", are you talking about a new cat that would be welded into the Z06 downpipe, or are you talking about a Z06 downpipe copy with a new cat? I cannot use a base C6 downpipe on the Z06 manifold, so it would have to be one of the above that I mentioned.
Old Apr 4, 2017 | 05:20 PM
CadVette's Avatar
CadVette
New cat welded to the ZO6 down pipe is the cheapest way to go. I'm pretty sure Magnaflow sells ZO6 down pipes with converters also. But since not many people are going to see it I'd just get the universal converters welded on. Recently my truck had a 3 inch Magnaflow cat start to rattle from the inside. The warranty just ran out at nine years old. For probably marketing reasons they only sold both sides at a time. I bought a new universal cat that was the same and had it welded on to the existing pipes for half the money.
Old Apr 4, 2017 | 07:20 PM
torquetube's Avatar
torquetube
Was the code P0420?
If it's the sensor, it would be the rear (downstream) one.
Old Apr 4, 2017 | 08:45 PM
buckmeister2
Originally Posted by torquetube
Was the code P0420?
It was not a numerical code. It was a word code, exactly as I described. My only concern is that it might be a sensor, as I have just purchased two more Z06 downpipes with working cats which will solve the problem, unless it is a sensor.
Thanks for your question, and reply.
Old Apr 4, 2017 | 08:46 PM
buckmeister2
Yeah, I checked on the Magnaflow cat/pipe....$600!! I just bought two more manifolds and two downpipes w/good cats for half that much, so I am good to go.
Old Apr 4, 2017 | 08:48 PM
buckmeister2
It's all set now. I am going to install the Z06 system before I worry about the code. If the cats are good, and the sensors are good, I will not have the engine light any longer. If I have to replace a sensor, no big deal.
Old Apr 4, 2017 | 08:52 PM
choppychop's Avatar
choppychop
Maryland speed just qouted me two LG high flow cats $350 delivered
Old Apr 4, 2017 | 10:23 PM
Mike's LS3's Avatar
Mike's LS3
There is a voluntary emissions recall (mandatory in CA) on 2008-09 models that replaces the original cats and add two more cats at the mid pipe. This is a free fix, but two more cats (total of 4) will be added.
The full 3" Z06 exhaust is a better exhaust and will require a retune. The Z06 exhaust manifold is basically a shorty header with 4 individual pipes that meet at the collector. So, if more horsepower is your goal, go with the Z06 exhaust.
Old Apr 4, 2017 | 11:44 PM
buckmeister2
did you specify Z06 cats? If so, that is certainly a better deal than paying $1200 for two magnaflows....
Old Apr 4, 2017 | 11:46 PM
buckmeister2
The full 3" Z06 exhaust is a better exhaust and will require a retune. The Z06 exhaust manifold is basically a shorty header with 4 individual pipes that meet at the collector. So if more horsepower is your goal, go with the Z06 exhaust.
Thanks, Mike, I am already aware of that, which is why I am doing it. Here in NV, we do not have to accept the recall, but I might do it in the future.
Jim
Old Apr 5, 2017 | 12:39 AM
torquetube's Avatar
torquetube
There's an underlying code there that isn't being presented by whatever scan tool they're using, then.
From the description it sounds like P0420 which happens when the signal from the downstream O2 sensor starts to look like the one from the upstream sensor, within some tolerance, suggesting an underperforming catalyst.
Graphing the live data from both sensors can give you a better picture but if the cat is bad you may want to look into why. A stock cat on a stock motor should last longer than 100K miles. Has your car been modified? Were there any other trouble codes set?
Old Apr 5, 2017 | 03:11 AM
Mike's LS3's Avatar
Mike's LS3
Jim
Ok, then I would install the Z06 exhaust and see if that resolves the issue. If not, install new 02 sensor.
Old Apr 5, 2017 | 09:07 PM
Dcasole's Avatar
Dcasole
I agree with Mike , does not matter if its the front, the rear sensor or the cat if you are replacing the system anyway
all this will do is pop another code as the sensors will send a lean code to the ECM .....
only if the CAT was bad
The header tune only turns off the rear sensors which are only there to measure the effectiveness of the cats
And you cannot turn off the front sensors ...... not without a lot of work as you would have to run the car in open loop .
if you have to turn off the rear sensors on a stock system ... somethings wrong , like a blocked cat ... and that could cause trouble ....
Old Apr 5, 2017 | 11:26 PM
buckmeister2
Bone stock, and no other trouble codes. The car spent it's first 100K in Kalifornia. They have a ton of fuel restrictions, some of which I have read are pretty hard on converters. I'm not concerned, as I will be doing the Z06 soon. If I still have a problem, we will tackle it at that time.
Thanks for the input.
To engine light...catalytic problems...
