Tires
Old Apr 12, 2017 | 09:34 PM
jrstuff's Avatar
jrstuff
1st Gear
Default Tires
My 2009 Corvette has nearly 15,000 miles. I am getting a lot of tire noise on the road. Dealer says the noise is normal. Any replacement tire recommendations that will be quieter on the road?
Rick
Old Apr 12, 2017 | 09:49 PM
extrapilot's Avatar
extrapilot
Anything other than the GY OEM tires will be quieter.
There's a host of tires, so maybe go to tire rack dot com and check the reviews and decide whether you need run flats or not, summer only types, or all seasons.
Old Apr 12, 2017 | 10:19 PM
C6 Snowboarder's Avatar
C6 Snowboarder
I think if you do a search and refine it to C6 section you could get a plethora of info on this.
Old Apr 12, 2017 | 10:53 PM
ls1121's Avatar
ls1121
St. Jude Donor '14-'15
Michelin Pilot Sport 4S, nothing more needs to be said, the Best!
Old Apr 12, 2017 | 11:02 PM
buckmeister2's Avatar
buckmeister2
Rick, you left out whether it is the original set, or not. If it is original, it needs replacing regardless of what the dealer told you. Did he even ask you if they are original? Don't go to a dealer with a question like this...
Regardless, almost any non-run flat will be quieter, and most run flats will be. Do some research here, and on tirerack.com for more info.
Old Apr 13, 2017 | 06:06 AM
extrapilot's Avatar
extrapilot
I do run the Firestones Wide Ovals run flats and are much quieter than the GY OEM's.
These are used as a DD on my car, great wearing, and should get 40K plus miles out of them.
Old Apr 13, 2017 | 10:47 AM
jbc1995fb's Avatar
jbc1995fb
Rick
Welcome to the forum. There's a lot of useful information on here, don't be afraid to ask questions, but you might do a little reading first.
Post some pics of your car. How long have you had it?
Old Apr 13, 2017 | 11:06 AM
jrose7004's Avatar
jrose7004
Search is your friend!
Old Apr 13, 2017 | 05:36 PM
cmonkey713's Avatar
cmonkey713
Michelins are the best you can run.
Old Apr 13, 2017 | 05:51 PM
acesx4's Avatar
acesx4
Old Apr 13, 2017 | 06:01 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
Rick
Asking for tire recommendations will get you as many suggestions as there are tire brands in the marketplace. However, the key issue with respect to road noise is that run flats, with their stiffer side walls, will always be more noisy than non-RF's, especially the OEM GY RF's which I presume are what you have. Best to do a search on Tire Rack or Discount Tire & focus on non-RF's. As many of us have done, carry a small 12 volt air pump together with a tire plug kit & you're all set.
PS - I'm running Nitto Invo's & find them to have great traction plus a very quiet ride.
Old Apr 13, 2017 | 09:43 PM
gilbybarr's Avatar
gilbybarr
Posted this up a few times in the last few weeks....but here you go....just replaced my original tires with Michelin Pilot Sport A/S3+....smooth, quiet.....very pleased thus far. Got good price from Discount Tire Direct (on line).
Old Apr 14, 2017 | 12:54 AM
NOWUCME's Avatar
NOWUCME
C6 of Year Finalist (stock) 2019
You didn't say if it's more than when the tires were new. Will assume it is if you are just noticing it. Low tread creates more noise, double that on OEM RF. And worse ride too normally. New tires could solve both. Dealer says it's normal...When?.....sounds like a pretty dumb response without qualification about the tires type and tread.
Old Apr 14, 2017 | 11:22 AM
richhoff's Avatar
richhoff
I just replaced the original Goodyears on my 06 with Michelin Pilot Sport runflats and was amazed with how much quieter they are. Very happy.
Old Apr 14, 2017 | 12:21 PM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
As someone said, almost anything will be better than the original Goodyears, especially when they're near the end of their life, but nothing is going to be Cadillac-quiet. I have Michelin PSS, nonrunflat, and they're still fairly noisy, especially on concrete roadways.
To Tires
