Ok, fellow members. I would like your opinion. I'm 70 years young and this quiet exhaust on my 2005 C6 is killing me. Should I do the muffler delete or drill holes and modify the mufflers. Spending hundreds of dollars on new mufflers is just not an option.
If you want a lot of noise, try the BB Bullets, but the highway drone drove me crazy. I went back to the factory NPP exhaust. I love it. Noise when the baffles are open and if you want it quiet, it turns them so they're closed.
Originally Posted by LSX228R
long tube headers, no cats, and m2w controller is what you need.
I do believe the OP said he did not want to spend a lot of money, so these seem to not answer his request.
I am with you on the stock system. I wanted to hear the exhaust. It is not a Toyota. I went the expensive route but I also considered the drilling process on the stock mufflers. I assume you read through the long thread on the process? Give that a try, before going to the delete option would be my advice.
Mod the stock mufflers. Simple if you have a lift, however can be done with Ramp. You can start with a 5/8" hole and try to see if loud enough then go larger by 1/8" steps to increase the noise.
I have been at 3/4" for 4 years and am able to now hear the engine at idle and not too loud at speed.
I did the muffler mod on the 07 coupe I owned and it sounded decent. I drilled a 1" hole and would have gone a little smaller if I had it to do over again due to a small amount of drone between maybe 1600-1800 rpm. It wasn't enough to be annoying but I prefer no drone.
I had a local muffler shop remove my stock mufflers, cut off the stock tips, bent pipe and welded my tips back on my 08 coupe. 65$! Best and least expensive mod I've ever done. I've taken the car on several trips on the interstate and don't have a problem with drone. At 55 you can hold a conversation at normal levels and honestly, I done hear any drone. Just my .02 cents.
Thanks for all the input guys! I just got back from test drive after drilling 1" holes through the inner pipe. Not bad at all, sounds a lot better if I leave the 1 1/4" hole open in the outer skin of muffler. Was able to do it with car on the ground. Very, very easy to do, even for a 70 year old. Will live with this for awhile before I decide on muffler delete
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
