05 not starting
05 not starting
I was hoping to get some insight from somebody on the forum. The cars a 05 and simply hitting the ignition button to start the car is starting everything except the engine. All the lights and dash turn on. After toggling to accessory mode and back off several times eventually the car will start. Its a problem that's been getting worse to where the thing will only start after many tries. Any insight as to what this might be? When the car does start it starts fine. Is it the starter or something before the starter? Currently having a shop look at it, but not sure they will figure this out.
Starter solenoids have been know to give connectivity issues. This one here is a real problem.
Check battery cabling also, and not a bad idea to have the battery load tested.
I'm sure its not the battery as I have had battery problems for years with this car and know the symptoms. Is the starter solenoid a part of the starter or before the starter?
Received 3,629 Likes
2016 C6 of Year Finalist
Is you car auto or manual? Do you have headers?
If it's a 6 speed manual my guess would be a bad steering column lock, or a bad / cracked starter solenoid.. WW
Cruising
OK---same issue I am having...following this as well. Did you get yours running if so---what was it???
Mine is Auto
Mine is Auto
