Engine light. Injector circuit problem
Old Apr 22, 2017 | 12:09 AM
Youmadbro's Avatar
Youmadbro
Default Engine light. Injector circuit problem
I keep getting po203 injector circuit 3 and po206 injector circuit 6 and misfire codes. I replace both pig tail on both injector sensor by using a quick splice. I'm thinking it a bad connection? I only replace those connector
Old Apr 22, 2017 | 01:20 AM
Don-Vette's Avatar
Don-Vette
Check all plug wires at both ends, possible bad coil pack.
Old Apr 22, 2017 | 10:03 PM
Cooter Tech's Avatar
Cooter Tech
What made you think it was a defective connector? What type of splices did you do? Pictures? If your spark plug wires are connected properly, Switch coil packs, see if problem moves, of just buy one and have a spare.
To Engine light. Injector circuit problem
