I installed my HUD from Cultrag and all and all it went OK. It took allot longer than the 4 hrs it went together OK. One issue is that when you open the door the window comes down a bit like it's suppose to. When I close the door the window does not go back up (Stow). I had the battery disconnected for about 12 hrs and was hoping all I needed is to reset it some how. I don't think any of the wires I disconnected and reconnected had anything to do with the windows but I'm asking for assistance. Thanks .
Did you do the re-index procedure? They are finicky unless that is done. Here is a link:
You have to re-index your windows every time you unhook the battery
You'll need to reset the window indexing (both windows) every time the car battery is reconnected. The procedure is in the owner's manual. I'd tell you what page, but you didn't tell us what model year C6 you had.
