HELP NEEDED Car wont start
Cruising
I have power to everything-except when I hit the start button nothing happens. All goes dead. I charged the battery-changed the battery-bought a new battery-had all the batteries tested. Checked all the fuses-changed ALL the fuses. Still nothing!!!
Car is turning into a lawn statue. (2008)
Checked neutral safety switch as well...HELP
Received 2,887 Likes
Might check the connections at the starter. Known problem area both hot and ground connections.
GL.
GL.
Cruising
Cruising
Yes---but taking it back and getting another one.
I just noticed the battery on its own will not power the car-I need to put the battery charger on boost in order for it to charge anything.
Going into town to replace the new battery I just bought. When I test the battery it shows charge-but when I turn the key it goes to zero (0).
Gremlins...gotta love em
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
Right. Have the store check it just as they would if you carried in an old one for testing.
Received 1,136 Likes
To check the positive cable/terminals, I would also just short the solenoid terminals with a screwdriver, and if the engine cranked over then there is a problem with the positive cable and/or connections. Ha, I don't think I'd try this on my C6.
But the safe way (on a modern vehicle) to rule out the far ends of BOTH battery cables as being the problem is to remove them, clean everything up with a wire brush, Scotch-Brite, etc. and re-tighten.
Cruising
I took the starter off and did the old fashion jumpers utilizing a vise- starter kicked over. I also tested the positive and negative cable for continuity-to ensure there was no short. All tested good. I traded my new battery for a new battery-changed all the fuses (after checking them). Hooked everything back up---Car started right up. I have turned it on and off several times-all is working as it should. The cause of the problem is still unknown-all contacts have NOW been thoroughly cleaned-maybe that was it. Maybe not---GREMLINS gotta love them
FWIW, continuity test on the cable: What you needed to know was: Is full current available between the battery posts and the terminals that they ultimately connect to? It might not be (if the terminals are dirty) even though the cable itself might be fine.
if the battery wouldn't power the car,it was ''JUNK'',,get a battery tender,if you don't drive it much,,''c-tek'' makes a great one,and make sure your alternater is charging the battery at 13.9-14.2 volts when idling,and charge the new battery over-night to fully charge it before using it
