Vacuuming the engine compartment
Old May 6, 2017 | 05:00 PM
The Director's Avatar
The Director
Default Vacuuming the engine compartment
South Carolina's roads are some of the worst in the nation. I get all kinds of dirt and small gravel inside the engine compartment. What do you guys use to clean that out?
I suppose I could just blast it out with the hose but I am betting one of you has a better idea.
Old May 6, 2017 | 05:11 PM
Vet Interested's Avatar
Vet Interested
My biggest issue when I drive from San Diego to Arizona & back is sand. I averaged 78mph on my last trip and the sand seems to hide everywhere. I do use a shop vac to get rid of most of the sand in the engine compartment. (I do not blow it out which makes it worse).Then wipe everything down with a damp rag. Everything looks new when done.
Old May 6, 2017 | 05:25 PM
Welker1's Avatar
Welker1
When I get sand (which happens often out here), I wipe the engine compartment down with a dry rag; if it's down where I can't get to it, I use my ShopVac to blow it out. I follow this with wiping everything down with a damp cloth lightly sprayed with a detailer ... engine compartment still looks great after 10 years & 90K+ miles
Old May 6, 2017 | 05:29 PM
Mike Green9's Avatar
Mike Green9
I use compressed air and then a cloth to wipe down the area.
M...
Old May 6, 2017 | 05:51 PM
windyC6's Avatar
windyC6
M...
Same here. I might ad that you can use one of those long wand type air nozzles with the rubber tips and then you can get into the nicks and crannies. Just remember to blow down the whole car when your done as of course some of the stuff from under the hood is gonna wind up on the car....
Old May 6, 2017 | 07:00 PM
Mad*Max's Avatar
Mad*Max
I use a hose and sometimes will use the vacuum to do "touch ups" during the driving season.
Old May 6, 2017 | 08:23 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
I have never found a shop vac very good at cleaning the engine compartment very well.
An air compressor would work a lot better, but I am thinking that your going to need a pretty big air compressor to effectively blow out the engine compartment real good (need a big supply of air)
So, what have I found that works the best? .... A gas powered leaf blower.
BTW ... a good gas powered leaf blower also is perfect for blow drying your car off after washing it.
Just my opinion
Old May 6, 2017 | 09:51 PM
LMB-Z's Avatar
LMB-Z
A fairly good size old rag, a long skinny screwdriver, some Armorall, and lots of time. Once you get it clean, its fairly easy to keep it that way. Just have to do it once every other month or so. I don't use air to blow, it just blows it some where else, where I usually can't reach.
Old May 7, 2017 | 07:36 AM
NashvilleGrandSport's Avatar
NashvilleGrandSport
I use one of these. Great for drying too.
Old May 7, 2017 | 11:19 AM
windyC6's Avatar
windyC6
Just my opinion
If you're using a 2 stroke, Just be sure that your leaf blower isn't throwing out your typical 2-stroke exhaust splatter all over your ride. Use to find little spots all over my car. They would come off, but couldn't figure out where they were coming from. Come to find out they were from my 2-stroke blower that I had been using for blowing off the car. The exhaust on the thing was in front blowing straight out......
Old May 7, 2017 | 04:43 PM
blittle's Avatar
blittle
The same for me.....
Old May 8, 2017 | 09:07 AM
Must_Have_Z's Avatar
Must_Have_Z
I absolutely love my Master Blaster blower. I use it to blow out the interior (never need to use a vacuum), the engine bay, the wheels/tires (brake dust), etc. Then I use it to blow out my garage and sidewalk. 8 freaking horsepower! Expensive but worth every penny.
http://www.autogeek.net/mema.html
Old May 8, 2017 | 10:54 AM
dmk0210's Avatar
dmk0210
Our roads are terrible here and I get a lot of small pebbles in the nooks and crannies around the frame.
I use my shop vac with the attachments to get in tight places. I also go under the car and vacuum around the rear suspension/transmission. A lot of stuff accumulates back there as well.
To Vacuuming the engine compartment
