Brake damage
Old May 6, 2017 | 08:30 PM
scotth48's Avatar
scotth48
Default Brake damage
How much damage to brake system if dot 5 is used and what needs to be replaced or can it be flushed?
Old May 6, 2017 | 09:26 PM
BlindSpot's Avatar
BlindSpot
Dot 5? or 5.1?
Old May 6, 2017 | 09:37 PM
scotth48's Avatar
scotth48
A guy on midwest corvettes fb site had a c6 that he bought used and brakes went out. Dealer said it was dot 5 in the system and going to cost $8000.00 to repair.
Old May 6, 2017 | 09:39 PM
LMB-Z's Avatar
LMB-Z
$8000??? I think I would get another opinion.
Old May 6, 2017 | 09:45 PM
scotth48's Avatar
scotth48
I told him that he was being coned!
4 new calibers , master cylinder and some stainless flex lines and a gallon of dot 4. Flush the system and install parts. Save even more by finding parts at a corvette salvage. That leaves only labor!
Old May 6, 2017 | 09:54 PM
ruxvette's Avatar
ruxvette
2016 C6 of Year Finalist
What? And the problem with DOT 5 is what?
Old May 6, 2017 | 09:58 PM
scotth48's Avatar
scotth48
Dealer said it ate all the seals up. I find it hard to believe!
Old May 6, 2017 | 10:03 PM
scotth48's Avatar
scotth48
Midwest corvette owners on fb.
Our Corvette is at the dealer. We were experiencing brake issues at the end of last year. Dealer just called to inform us that the man that owned the car before us put the wrong brake fluid in the car and not only ate through all the seals and ruined all brake lines etc. We are absolutely sick to our stomachs. Not how I wanted to spend $8k this weekend"
Old May 6, 2017 | 10:05 PM
ProCycle's Avatar
ProCycle
Absolutely true. DOT 5 is silicone based and is not compatible with a lot of brake components that are used with DOT 3 or 4 systems. DOT 5.1 is fine.
I imagine the high cost has to do with replacing the ABS and maybe some stability control components.
$8K does sound a bit steep but calculated at dealer parts prices with dealer labor probably is about right.
Old May 7, 2017 | 04:51 PM
BlindSpot's Avatar
BlindSpot
But, $8K doesn't surprise me at a dealer. They'll take the opportunity to replace everything and, why not, to be on the safe side.
Old May 7, 2017 | 10:47 PM
ProCycle's Avatar
ProCycle
No doubt there will be an independent shop who can do it for less. It's worth calling around and getting a few quotes.
To Brake damage
