Wanting to keep my car streetable but bump up the up.Car is a 2012 Grand Sport coupe with dry sump and 6speed manual.
What would you do as far as heads and cam plus headers car has npp and want to keep that So I need some help and good advice.
Short of just adding nitrous, the easiest way to streetable, reliable horsepower is a supercharger kit. There are lots of good choices from A&A, ECS, Edelbrock and Magnuson. I'd add a set of long tube headers as well if your emissions regulations will allw them. If you do the labor yourself, budget for 8-9 grand.
Will be a night and day difference when you get on the loud pedal.
Intake/headers/tune can give a solid 40-50rwhp bump that maybe more than enough for you. Past that, you start to dive into a heads/cam/etc setup, that can kill gas mileage/drivability/etc.
ECS/A&A kit are awesome, bolt right on, and can give an easy 150+rwhp and still drive like stock.
