clunking in the diff?????????????+
Old May 17, 2017 | 02:47 PM
knut's Avatar
knut
2nd Gear
Default clunking in the diff?????????????+
corvette c6 clunking when i shift to 2 gear . worst is there in first gear when i accelrate. What is this
Old May 17, 2017 | 03:24 PM
CMY SIX's Avatar
CMY SIX
must be new to the English language, my xray long distance vision broke this week, but if I had to guess I'd say your couplers are shot.
Old May 17, 2017 | 04:31 PM
knut's Avatar
knut
2nd Gear
Sorry for my bad English. The car is a 05 z51 with manual gear. The sound is a dunk when a clutch is released .. and when one releases gas in the first gear
Old May 17, 2017 | 04:55 PM
Red08's Avatar
Red08
If you are releasing gas in the first gear, I would suggest laying off the beans or broccoli
Old May 17, 2017 | 04:59 PM
DOOKEY's Avatar
DOOKEY
That's the side effect of your vtec kicking in bro.
Old May 17, 2017 | 05:13 PM
449er's Avatar
449er
CF Community Team
This is a helpful post
Old May 17, 2017 | 06:02 PM
Hells's Avatar
Hells
St. Jude Donor '08
Hang in there knut. Someone will chime and actually help you out with your "question".
Old May 17, 2017 | 08:32 PM
65GGvert's Avatar
65GGvert
Pull the caps off the rear wheels, get a 34mm socket and torque the rear axle nuts to 140 ft lbs. There's a TSB out that says to replace the nuts with new ones and torque to 160 ft lbs, but stock was 140. Just pull off the center caps, not the wheels. Takes about 2 minutes. If that doesn't fix it you can go farther, but it stopped mine. You can also search for the TSB and read it for yourself. Use "TSB for C6 axle nut popping" or something similar. All from 2005 thru at least 2013.
Old May 17, 2017 | 09:09 PM
Rocketmanwpb's Avatar
Rocketmanwpb
Also could be just a fluid change for the dif. I do mine regularly. I recommend the stuff they sell at the GM parts counter. Clunking is a sign the fluid needs replacement. As also suggested check the axel nuts.
Good Luck.
Old May 18, 2017 | 10:03 AM
irok's Avatar
irok
another thing to check would be your end links
Old May 18, 2017 | 10:44 AM
wayback's Avatar
wayback
Mine is at the transmission shop now for a simular issue. Mine makes a clunk when you release the brake pedal quickly at low speeds or when you come off the throttle in 1st or 2nd. I think it is an output bearing but they will find out.
Will post when it is resolved.
BTW mine would make noise when rear tire was rocked back and forth while in gear or park.
To clunking in the diff?????????????+
