LED switchbacks
Old May 19, 2017 | 11:44 AM
Nick_04k's Avatar
Nick_04k
Default LED switchbacks
Who has forced the DRL to stay white without buying the radioflyer harness?
Id like to avoid the $120 harness if its possible while keeping the wiring clean.
Old May 19, 2017 | 12:02 PM
RC4G's Avatar
RC4G
Not possible.
I believe that the harness uses an IC to use a feature within the switchback LED bulb that activates the white running light when both the running light and the turn signal circuits receive voltage at the same time. When the IC receives voltage on the yellow circuit longer than standard turn signal flash duration a timer activates and sends votage to both circuits for the duration that the yellow circuit is receiving sustained voltage. This is why when the DRL's first light they light yellow for app. 2 seconds before switching to white.
Your only alternative for a white DRL without the IC harness is to use a white-only LED bulb.
Old May 19, 2017 | 01:47 PM
Nick_04k's Avatar
Nick_04k
Originally Posted by RC4G
Not possible.
Very conclusive! Thank you very much. Take my money radioflyer lol
Dcasole's Avatar
Dcasole
Not possible.
Not sure by what you mean " Keeping the wiring Clean" , Radio's harness looks like it could be factory installed .....
Dave
Old May 19, 2017 | 02:15 PM
Nick_04k's Avatar
Nick_04k
Read it again and you'll see i was referring to keeping the wiring clean WITHOUT buying radioflyers harness. I agree completely that they did an excellent job with their harness.
I have already ordered it.
Old May 19, 2017 | 02:37 PM
Hells's Avatar
Hells
St. Jude Donor '08
I just use white DRLs that are always white. No wiring harness needed. Although I do have hyper flash but it doesn't bother me.
Old May 19, 2017 | 04:08 PM
z06Don's Avatar
z06Don
I use white always DRLs as well....I only had to cut one wire on each one to install the load resistor. I got mine from JWM....they match my low beams and my drivin lights.
Old May 19, 2017 | 06:11 PM
Dcasole's Avatar
Dcasole
you will love the new LOOK
Old May 20, 2017 | 09:37 AM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Looks like the OP has it figured out, but we do offer an all white LED bulb for those that only want white. PM for more.
Old May 21, 2017 | 07:37 AM
truckplay's Avatar
truckplay
same here, been like that for years
To LED switchbacks
