alignment
Old May 23, 2017 | 02:48 PM
mmorse's Avatar
mmorse
Default alignment
getting new tires and getting a bunch of different numbers for cost of alignment. what is the typical cost for a four wheel alignment for a c6 z51?
Old May 23, 2017 | 02:55 PM
LsLegacy's Avatar
LsLegacy
I just paid 100$ even for 4 wheel alignment, putting in new tpms, calibrating the tpms, and putting my new wheels on. But then again, I have family that work at a tire shop.
You're probably looking at 80 for the alignment alone.
Patriot Six's Avatar
Patriot Six
$100-125
Old May 23, 2017 | 03:20 PM
Homer3D's Avatar
Homer3D
$100 for an alignment after I put coilovers on my 2005
Old May 23, 2017 | 05:44 PM
rkj427's Avatar
rkj427
Pro Mechanic
$100.00 here in Michigan at numerous locations, just pick the one you trust the most to perform the work correctly.........
Old May 23, 2017 | 06:40 PM
Not So Fast's Avatar
Not So Fast
$97 at the stealership, both times and apparently they did a decent job
NSF
Old May 23, 2017 | 06:47 PM
buckmeister2's Avatar
buckmeister2
My local Chev dealer has it priced on special at 79.99. check your dealer out.
Old May 23, 2017 | 06:52 PM
ls1121's Avatar
ls1121
St. Jude Donor '14-'15
I went with Firestone I believe it was $179.00 lifetime alignment, no matter how many times.
BlindSpot's Avatar
BlindSpot
I do my own, but hear $100-$150 in my area (not including specials).
Old May 23, 2017 | 07:07 PM
Vet Interested's Avatar
Vet Interested
I also did lifetime at Firestone using Pfadt's settings.Think it was $169..anyway I get the alignment checked EVERY 5,000 miles. Tires have 18,500 miles on them and still look new.
Old May 23, 2017 | 07:17 PM
mmorse's Avatar
mmorse
thx for the replies! just checked with my stealership and they want $160. then again they want $90 for a tire pressure sensor!
Old May 24, 2017 | 08:32 AM
Patriot Six
Stay away from the dealership for tires. They wanted over $1200 to mount, balance, and install TPMS on four wheels/tires. I almost had an aneurism.
Local tire shop did it for about $800 less.
Old May 24, 2017 | 09:50 AM
ruxvette's Avatar
ruxvette
2016 C6 of Year Finalist
Same in WA. Just make sure the shop will set to EXACTLY the numbers you want...not just "within range".
Old May 24, 2017 | 10:30 AM
Landru's Avatar
Landru
$100-$150 sounds about right.
If getting an alignment, and not tracking?
Consider Pfadt's 'Performance Street" spec done.
Just printout top chart @ link & give it to shop. http://www.pfadtracing.com/blog/wp-c...-alignment.pdf
Won't cost a cent more vs stock.
C6 came w/ an aggressive alignment from factory, too much camber?
While suitable for track use, normal driving wore insides much too fast.
Can attest PPS specs prolonged wear on my Z06 at least 2 fold.
Wished I'd known of Pfadt much sooner for my C5, '06 C6 and first 3 sets of very expensive skins on Z.
Old May 24, 2017 | 12:32 PM
dmk0210's Avatar
dmk0210
I had my local shop do mine for about $80.
The PFADT street specs are within factory specs so there's no reason in the world why they can't do it. You are just optimizing within the factory tolerance, which is a pretty wide range.
Old May 24, 2017 | 03:55 PM
mmorse's Avatar
mmorse
$400? does that include the cost of the tires or just labor?
mmorse's Avatar
mmorse
thx for the info! had camber issues with my two c5 zo6s but has not been an issue with my c6. have had three sets of tires on my c6 and never had an alignment and they all wore nice and even. still no issues with pulling or uneven wear but figured at ten years old and 70k miles, i think it's time to get it aligned.
To alignment
Old May 25, 2017 | 02:54 PM
MH663's Avatar
MH663
Old May 25, 2017 | 03:21 PM
mmorse's Avatar
mmorse
Originally Posted by MH663
not my dealer. $160
Old May 25, 2017 | 03:38 PM
NashvilleGrandSport's Avatar
NashvilleGrandSport
I had a local Corvette specialist do mine at his shop. He even put 200 pounds of weight in the driver's seat to replicate my being in the car. Spent almost 2 hours doing the alignment. The tire wear and everything else is great 10,000 miles later and I have no issue with the cost.
The original rear tires were completely worn down on the outside edge before new tires and the alignment.
