Trunk space
Old May 31, 2017 | 01:50 PM
Jcbarr25's Avatar
Jcbarr25
Default Trunk space
How many tires for a Grand Sport can you fit in the hatch? Can I at least fit the two rear ones? Or front ones? Just tires with no wheels. Hatch must close.
Old May 31, 2017 | 03:05 PM
flyingbunnys's Avatar
flyingbunnys
Is it a convertible?
Old May 31, 2017 | 03:08 PM
jaredtxrx's Avatar
jaredtxrx
I would say 3 tires in the hatch and two of them being the fronts. MAX.
Old May 31, 2017 | 03:13 PM
Jcbarr25's Avatar
Jcbarr25
Coupe
Old May 31, 2017 | 03:14 PM
Jcbarr25's Avatar
Jcbarr25
thanks. That would be great. I can measure right now because I am not home. So any suggestion will help. I am moving and towing the car and buying new set of tires but do not have time to install so I am trying to figure out if I can fit most of them inside the car itself.
Old May 31, 2017 | 03:16 PM
MH663's Avatar
MH663
There was a thread about a month ago with pictures. It was a coupe and I believe all four. Cant remember for sure however.
Old May 31, 2017 | 03:25 PM
jbc1995fb's Avatar
jbc1995fb
Not sure about just the tires, but with the wheels, not many....
Old May 31, 2017 | 03:43 PM
flyingbunnys
[QUOTE] I am moving and towing the car and buying new set of tires but do not have time to install so I am trying to figure out if I can fit most of them inside the car itself. [QUOTE]
So if the car is being towed, two should fit in trunk and can the other two occupy the cabin area where people usually sit? You could defiantly get all 4 then.
Old May 31, 2017 | 08:19 PM
HOXXOH's Avatar
HOXXOH
You can put the 2 rear tires in the back if you stagger them with one in the left rear corner and the other toward the right front and partially on the fuel crossover channel. You might be able to fit the 2 front tires on the passenger seat. I've transported my drag tires/wheels this way several times, but my fronts are skinnies, so the GS width might be an issue. The alternative for the fronts would be one on the passenger seat then fold and move the driver's seat to the front limit for the other tire.
If you are packing other stuff in with the tires, periodically check for clearance on the struts by closing the hatch.
Old May 31, 2017 | 11:48 PM
bop's Avatar
bop
Take them to Fedex and have them ship them.
Old Jun 2, 2017 | 01:45 PM
echelonphoto's Avatar
echelonphoto
You will not be able to fit two fronts in pass seat. I have tried this
Old Jun 2, 2017 | 02:18 PM
LoganExplosion's Avatar
LoganExplosion
How would he get them to fedex?? ha. This is The fox, the hen and the corn all over again!
Old Jun 3, 2017 | 10:09 PM
jbc1995fb's Avatar
jbc1995fb
Make 4 trips.
To Trunk space
