Harmonic balancer concerns
All the years of the C6 are using the same style harmonic balancer from GM. The 2 concentric components are separated by rubber, and that rubber is prone to failure.
Also, there is no keyway keeping the balancer in place - just a press fit, tightened by the crank bolt. Over time the bolt can loosen and the balancer starts to slip. (GM started using a friction washer with the 2006 model year - didn't help much.) If the balancer starts to slip on the crankshaft, you will hear chirping and squealing.
Idle the engine and look at the balancer for wobble. Have someone rev the engine and see if the pulley moves outward. If it does, then a failure is in the making. If it does not, don't worry about it. A small amount of pulley wobble (1 - 2 mm) is acceptable. Also, look for belt fraying.
I cannot tell you how long it will take to completely fail once it starts to go bad. Driving habits (right foot syndrome
) will dictate that. I have read a post that suggested that because old belts stretch, this may promote the premature rubber failure. So changing belts might be a way to avoid a problem.It's a big job to change because the steering rack has to be pulled to allow the removal of the balancer. Figure on 6 to 8 hours by someone who knows what they are doing $1,200 - $1,500, plus the balancer, and a wheel alignment.
Best to replace with a balancer from ATI or SLP - NOT GM.
My '08 has 26,400 miles with no balancer issue. I do worry about it though.
However, this should not stop you from buying a C6. They are awesome!
Hope this helps,
M....
What would anyone do if they saw the slightest wobble in the - Alternator pulley, the waterpump, the PS pump pulley or the tension pulley?
The notion that a slight amount of wobble in the HB is OK comes comes from the guy who takes it in to the Chevy dealer. Tech says you have a bad harmonic balancer. Owner says how much to replace it? Dealer says $1200. Owner throws a fit and says THAT'S RIDICULOUS!!!!! Dealer says, well....a small amount of wobble probably isn't going to hurt anything. How about just watch it. If it gets worse then change it.....
I've had some "clowns" say - "Duh...Hay man...How ya gonna get that outa there if ya ever have ta change it man?" I just roll my eyes....
What I meant was that as the engine is rev'd, the pulley (outer part of the balancer) may move outward a mm or two. That would be the distortion of the rubber portion of the balancer under the load of the belt.. At least that is what I have observed on any of the LS* engines with stock balancers that I have seen.
Sorry for the confusion.
M....
It can be replaced for about $400 to $700 in labor, depending on location. You will see it wobbling quite a bit as it gets worse, and will hear whine when it is bad. It is not the end of the world, or anything to fear. I have a friend whose HB has been wobbling for 30,000 miles, and he drives his car everywhere.
Anyway, that is the only complete failure I have read about here.
I bought my car knowing the balancer was wobbling. I pointed it out to the previous owner and he dropped his price by $1500.00..
For me, "keeping an eye on it" was not an option. I don't knowingly leave any bad part on any of my vehicles so I just put on an ATI the day after I bought my car.
Don't let it keep you from buying. LS1, LS2 and LS3 all have the same problem.
Budget the money into your purchase and never worry about it again. Or, you can "keep an eye it"
I don't even think about it unless it comes up here. I say buy one and be happy. I have not been able to wipe the smirk off for three months now
Next up issue.....the dreaded lock in Park issue. Any you tube videos of removing the center console in the '05 C6? Thanks for any directions....
