HELP...'05 A4 won't shift
Old Jun 12, 2017 | 10:34 PM
tr0569's Avatar
tr0569
Default HELP...'05 A4 won't shift
I came home tonight after a drive and pulled in the driveway. I left the car running to move something to pull into the garage and, when I went to shift into reverse, the shifter moved but did not engage (it stayed in park even though it was in the reverse position). It seems very loose and the shifter will move into any position but it won't actually shift out of park. Any ideas?
Old Jun 12, 2017 | 11:46 PM
02_NHRA_TA's Avatar
02_NHRA_TA
Shifter cable broke. Do a search and you'll find info on how to fix it.
Old Jun 13, 2017 | 12:37 AM
EVRose's Avatar
EVRose
Amazing how often this happens in the garage or driveway. Best place if it's gonna happen.
Old Jun 13, 2017 | 01:01 AM
owc6's Avatar
owc6
You are very lucky this happened at your home.
When this happened to me, I was not (30 miles away). I got a ride home, and it took ten hours to get a tow the next day.
Old Jun 13, 2017 | 01:56 PM
RICH 28's Avatar
RICH 28
Mine broke at a gas station and I was blocking the pump during rush hour. I fixed it there since I'm too cheap to pay for a tow. I have a thread on this.
Old Jun 13, 2017 | 02:25 PM
tr0569's Avatar
tr0569
I was very lucky to have this happen at home right after I left the airport (1.5 hours away). Thanks for all the input I was able to find the broken bushing and replace it. Back on the road again for a $7 fix!!!
Old Mar 22, 2019 | 05:27 PM
883stump's Avatar
883stump
Default Stuck in drive...
My 98 will not move out of drive.... The shifter moves freely but will not shift out of drive.
I have removed the shifter assembly the shift cable is securely attached.... What could be my issue?
To HELP...'05 A4 won't shift
