Electrical gremlin?
Old Jun 13, 2017 | 03:58 PM
RadarP3C's Avatar
RadarP3C
Default Electrical gremlin?
I posted this first in the tech section, but no responses.
As I'm leaving my neighborhood, I notice the AC not cooling. Then I see the DIC message, "Engine Hot Air Conditioning OFF." The temp gauge needle has not moved from it's coldest temp.
I went back home and let it sit overnight. This morning I put it in engine mode and immediately get the message "Engine Hot Air Conditioning OFF." I did not start the engine.
I disconnected & reconnected the battery. Started the engine, temp gauge is now working and no DIC message. All is right in the world now.
Anyone else had or heard of this problem? Hopefully it was just one of those pesky gremlins acting up and nothing more serious.
Old Jun 13, 2017 | 04:06 PM
extrapilot's Avatar
extrapilot
More than likely....
Old Jun 13, 2017 | 04:25 PM
hrt vlv's Avatar
hrt vlv
If you have access to IR temp. gauge it makes easy, non intrusive testing of possible problem. I would suggest you verify T stat, radiator operation, fan connection, ECM connections, all connections in passenger foot well. Just to give you some peace of mind.
Old Jun 13, 2017 | 04:38 PM
nick14003's Avatar
nick14003
there is no such thing as a gremlin,
everything happens for a reason
cause and effect.
cause? condensation + electrical connectors + copper = corrosion
Hopefully it's so mild that it will stop, but.... with no changes, it will eventually come back, this is our reality
Old Jun 13, 2017 | 04:58 PM
RadarP3C's Avatar
RadarP3C
Yes, that is why I posted this. Thanks! Out of all your suggestions, I can verify the fans were operating at the time.
cause and effect.
I realize the use of the term "gremlin" is a broad brush term used for an unexplainable event. Again, that is why I posted on here to give someone the opportunity to give me a solid explanation of what might have happened. Yes, I don't want this to happen again.
Old Jun 14, 2017 | 10:17 AM
Landru's Avatar
Landru
I disconnected & reconnected the battery. Started the engine, temp gauge is now working and no DIC message. All is right in the world now...Anyone else had or heard of this problem? Hopefully it was just one of those pesky gremlins acting up and nothing more serious.
Happens all the time, sometimes w/ AC sometimes other functions.
But truth is for reasons no one knows a reboot often rectifies these bugs.
At shutdown/start-up all computers are supposed to rest, but...
Why whenever I hear a weird symptom I always suggest a reboot, first.
In your case it worked, for now anyway; because, it isn't unusual for AC head units to go south, either.
Happens again, be thinking HU.
Old Jun 14, 2017 | 10:47 AM
windyC6's Avatar
windyC6
Help a dummy here....is "engine mode" some new wave term for something us old farts may be familiar with being called something else like "accessory"...or "ignition".....etc ???? If not....then what is "engine mode".....thanks....
Old Jun 14, 2017 | 11:44 AM
RadarP3C's Avatar
RadarP3C
Ignition, ... sorry.
Old Jun 14, 2017 | 06:12 PM
nick14003's Avatar
nick14003
Some might say, there is no such thing as an unexplained event, only one that has yet to be discovered...
To Electrical gremlin?
