Grease fitting
Old Jun 17, 2017 | 03:24 PM
lwise4's Avatar
lwise4
Default Grease fitting
I noticed a strip of black goo on my left rear wheel on my 2008. I pulled the wheel off and could see nothing leaking? I greased the fitting on the rear linkage and when I pulled the grease gun off, there was a steady stream of grease running out of the fitting.
I took the fitting off and cleaned it but it still leaked after reinstalling. I went to Auto Zone to get a replacement and of course you have to buy a pack! The guy at Auto Zone told me that all of the later cars had METRIC fittings so I bought a pack. I put the fitting in the link and it was too small, so back to Auto Zone! This time He pulled a SAE fitting from a pack and compared it to my fitting, not the same so He steered me to Tractor Supply. I ended up with SAE fittings and it did screw in but I still do not think it was the correct one.
I have the manuals and I cannot find info on the fittings. I believe that only the Z51 and maybe the Z06 has these fittings? Anyone know the correct thread size?
Old Jun 17, 2017 | 06:09 PM
jost6453's Avatar
jost6453
If the one from TSC screwed in, what's the problem? If you are concerned about a little grease leakage, just put a little 5 min epoxy on it before you run it in. Problem solved.
Old Jun 17, 2017 | 06:51 PM
Kenny94945's Avatar
Kenny94945
With all the driving around...why not order a GM zerk at your local dealer?
Good luck.
Old Jun 18, 2017 | 11:19 AM
lwise4's Avatar
lwise4
It screwed in but it would not tighten. It does work though! I put grease in and it stays in! I do think that it is Metric but whatever works!
Old Jun 18, 2017 | 11:25 AM
lwise4's Avatar
lwise4
Good luck.
My "local" dealer is not as local as Auto Zone and it was Saturday. The 1/4 zerk did screw in it would just not tighten but it is good enough, there is no more grease leaking out. I just do not understand why it is so difficult to get information on the zerk! As I mentioned, I have the manuals and I went online to GM Parts and still could not get a answer. I bought the car 8 months ago so I do not know the last time it was greased. Most vettes do not have these fittings but the Z51 option does.
Old Jun 18, 2017 | 11:52 AM
John Harry's Avatar
John Harry
St. Jude Donor '10-'11-'12-'13-'14
If your local dealer is not convenient (or is not helpful) contact Gene or Patrick at http://www.cultragfactoryparts.com/. They are a Forum Sponsor and a good source for parts.
Old Jun 18, 2017 | 12:29 PM
lwise4's Avatar
lwise4
As I mentioned, it was a Saturday and my wife wanted to put Her car in the garage! I did look at GMPARTS.com and found nothing! I googled ZERK FITTING and found out that there are many, many varieties and sizes! I have had 14 Corvettes and numerous other vehicles and have never had a bad ZERK fitting, nor did I expect to have trouble finding the right one!
Old Jun 18, 2017 | 02:05 PM
HOXXOH's Avatar
HOXXOH
Cars with the F55 option also have fittings to grease that joint. It's only the base suspension cars without them.
Old Jun 18, 2017 | 02:33 PM
Bruze's Avatar
Bruze
No kidding, didn't know that. I will have to check mine.
Old Jun 18, 2017 | 03:11 PM
Mike Green9's Avatar
Mike Green9
F55 Zerk (2008 C6)
M...
Old Jun 18, 2017 | 04:14 PM
Bruze's Avatar
Bruze
Thanks Mike ^^
Old Jun 19, 2017 | 10:51 AM
lwise4's Avatar
lwise4
I had a car with the F55 option, I did not have it long enough to require a service. It was a 2003 Anniversary car and when I drove it home, I thought it was the worse driving Corvette that I had ever had, and I had a few C3's. Turns out the problem was that no one had ever removed the "Shock Stuffers" which are plastic blocks that keep the shocks from moving during transport. That meant that there were no shocks!
Thanks for your reply, it sounds like one member is now aware of the fittings!
Old Jun 19, 2017 | 10:53 AM
lwise4's Avatar
lwise4
Originally Posted by Mike Green9
F55 Zerk (2008 C6)
M...
It looks like it could use some grease? I put grease in mine and it just came back out like a strand of spaghetti!
Old Jun 20, 2017 | 09:21 AM
Mike Green9
That's a pic of mine before I greased it.
I grease mine in the fall before winter sleep. These days I do about 2,000 miles a year. Yes a little goop comes back out, but I let it sit on the lift for a while and keep wiping it off. After a while it stops.
M...
Old Jun 20, 2017 | 10:20 AM
Bruze's Avatar
Bruze
The grease shouldn't come back out the zerk.
I greased farm machinery when I was a kid -- not to mention older cars I had that had numerous grease spots -- and we pumped until the grease bled out from under the rubber cover. It never came back out through the fitting.
Did they re-invent grease fittings? Like they keep re-inventing Windows and each version is worse than the last.
Old Jun 20, 2017 | 10:29 AM
lwise4's Avatar
lwise4
M...
LUCKY LUCKY You have a lift! I scraped the skin off of my tail bone wiggling under the car to put a skip shift on the transmission. I think that I am getting too old for that work.
Old Jun 20, 2017 | 10:34 AM
lwise4's Avatar
lwise4
Beats me! If you google ZERK FITTINGS, there are companies that make many different styles and sizes. As I mentioned I have seen and pumped grease into many a ZERK fitting and none spit it back out. I also worked in a gas station and did hundreds of grease jobs. I did run in to fittings that would not take grease because they were plugged up!
To Grease fitting
Old Jun 20, 2017 | 02:20 PM
HOXXOH's Avatar
HOXXOH
It only takes a tiny piece of sand/grit to get stuck between the ball and seat to have grease spit back out. Always clean off the zerk first. Also wipe off the end of the grease gun before starting a grease job.
Those were primary rules when I worked part-time doing lube jobs and oil changes in '59/'60. The station owner said clean it before you start and clean it again when done.
Try taking the zerk out and soak it solvent (gas works) for a while, then push the ball in with a paper clip and blow some air in the backside.
Old Jun 20, 2017 | 02:27 PM
lwise4's Avatar
lwise4
I tried the paper clip and solvent but it still spit out the grease. The ZERK I put in screwed in OK but it will not tighten which makes me think that it is the wrong one? The grease does stay in the joint though. I posted this because I was curious why I cannot seem to find a description or part number for the ZERK? Thank for your post though!
Old Jun 21, 2017 | 10:28 AM
jshot00's Avatar
jshot00
Don't guess my 2012 GS has that!
