You may have the Left side lights on the right side and vice versa. All thought they look the same they do normally label them (light) so you put the left on the left and right on the right. Pull them out and play with them.
I think when I got mine they were labled #1  Now you tell me theres a difference
Been battling a hyperflash intermittently ever since.
Hey if I was you call a vendor and see if they can point you in the write direction. I would say Corvette mods if they sell them. I know it's crazy rite. Hell they all look the same and should fit the same and they have certain spots they have to go in. I think when vendors sell those on their site they be like, hey watch this Then when someone call they be on the floor rolling around laughing. LoL
I can't remember another thing you could do but this may be a long shot but see if the wires are the same color on both ends plug in side to resistor and if so then try to match the colors if they are the same. Sorry I'm not much but I'm trying may just want to have the car on not in the run position and have the blinker on and pull the lights out until you can figure out and stop the hyper blinking. Is it on both sides also because if not you may have a front blinker out?
Thanks guys I'll swap them around this weekend.
SOmewhat of an odd situation with mine.
I do have the latest switchbacks up front. SOmetimes if I just energize the TS It'll work as normal(no hyperflash), until I step on the brake pedal. Then the Hyperflash will start. Then sometimes its hyper all the time.
What should the ballast resistor read Ohm wise?
