Radar detector plug ins
When it come to reading wiring diagrams, I'm the dumbest guy on the planet. Can someone direct me as to which ports in the mirror plug I should use to direct hook a Valentine V1 into the power on the mirror plug? Thanks in advance.
Received 2,093 Likes
[I]MirrorTap instructions for the V1. Turns out MirrorTap has at least two different plugs. One with thick leads and one with thin leads. Naturally they sent me the one with thick leads first which did not fit. Once I got the thin leads they fit perfectly. Good luck.
pagosawingnut (06-27-2017)
Sorry Vet Interested, the pic won't open on my computer. Thanks for the effort. Could you tell me the plug in ports? I might be electronically challenged but I can count...........
You need to try to open this on another device the see the picture which will make it easier.
Maybe you can open it now....
I've had bad results with sticking those pins into connectors that were not designed to have extra parts stuck in them. Erratic connections work one day, not the next. I always go to the fuse box.
Retired & lovin' it!
...and I added solder pins from Radio Shack to the harness I installed back in '05 & have never had a problem with the power connection to my Valentine in the past 12 years!
Received 2,887 Likes
I used an add a fuse in the footwell fuse box. Working for 10 years now. V1 is being displayed in the heads up display also.
Thanks for the help gentlemen!
Glenn (Vet Interested) sent me a picture and going by that, I got it working as I wished. Thanks for your time and trouble and all the replies.
Rick
Rick
