I was looking. Where exactly do you enter your location.
If I remember right, click on your username. Hit "View Public Profile". You will see a tab "About Me". Hit it. You should be able to edit your location.
I just did that but it doesn't show in my avitar. It only shows if you visit my profile. I want it to show under my member since like yours does.
I did just what you said but it won't show: I assume you are talking about this.
Not sure what is wrong. In the screen shot of yours click in the right corner hit "View your about me as seem by everyone else". Make sure you put something in the "City" tab. Make changes there and save.
Check out the PM I sent you.
Now were talking, I guess like you said you have to also enter a city. Thanks for all the help. Back to the topic at hand!
finally got the alignment done. Rt 66 did it & gave me a read out. Charged me $100 which was their normal price. Most of the discount shops want $70.
Most concerning, my left front was down to the inside cord when I replaced tires but all the specs were within factory, the toe was .05 deg (now zero). Now the right front (the one I replaced last year due to hitting a pot hole) was way out at .53 deg (now zero). Last year when I replaced the right front they supposedly checked the alignment as "good."
I really can't explain why the left front was worn so badly given that the alignment was "green" and within factory specs. In fact, other than the right front toe, everything was "green."
Now I have everything very close or right on PFADT. A couple of measurements were one significant digit next to true and all the rest are right on now.
I can't tell much difference driving the car. It goes straight & comfy with new tires + PFADT.
If you don't mind traveling a little, firestone on robinson in Norman, the manager is an avid Vet guy or merles on south shields. both excellent shops for corvettes
