LS2 vs LS3 throttle response
Old Jul 10, 2017 | 09:17 PM
hubes's Avatar
hubes
Default LS2 vs LS3 throttle response
I'm currently in the market for a C6 corvette, and I'm doing some research. I know what the dyno numbers say power wise, but I'm wondering what one, if either is snappier. It makes sense to me that the cathedral port LS2 heads would have better throttle response than the square port LS3 heads. But on the other hand the LS3 has more cubes, and I can see the different intake maybe helping. So I'm hoping someone who's driven both a fair bit can tell me what one feels snappier at low to mid rpm. Thanks
Old Jul 10, 2017 | 09:28 PM
nick14003's Avatar
nick14003
Not sure about snappy, but avoid the 05, lot of recalls which leaves with 06 07 08+ if price difference is minimal I'd say go with the 08, even if the ls3 isn't as snappy, a few small mods and it will be easily.
Old Jul 10, 2017 | 09:36 PM
cadyshac's Avatar
cadyshac
I have a '05 LS2 w/ Z51 and manual trans. My wife has a '13 Camaro SS with LS3. I don't think you would be disappointed with either one and probably not a huge noticeable difference on the butt dyno. Don't rule out a '05 if you come across the right one. No complaints about my LS2 so far but the LS3 has proven to be a solid choice.
Old Jul 10, 2017 | 09:47 PM
ruxvette's Avatar
ruxvette
2016 C6 of Year Finalist
Politely, anyone saying "avoid the '05s" has probly never owned one.
I had an '05 with the Z51 package which has a little shorter gearing, hence snappier. Automatic cars were also offered with a "performance" rear-end ratio.
The last year I had my '05 I also had my '11 GS and, jumping out of one and into the other, it was hard to tell the difference in normal to peppy driving.
Buy the newest, lowest mileage car you can afford...that checks all the boxes on your wish list. LS2 or LS3.
BTW...I put 50k miles on my '05. Trouble free.
Old Jul 10, 2017 | 09:52 PM
hubes's Avatar
hubes
I definitely want a manual Z51, so really I'm looking at 06-09. I don't mind paying a bit more for a newer one if it's worth it, but 07's are easier to find (a lot more made) and I'm a big fan of low end torque and throttle response. According to dynos I've seen they're the same power up to 3500 rpm, but dynos don't measure throttle response and part throttle power.
Old Jul 10, 2017 | 09:54 PM
owc6's Avatar
owc6
At this point, there is no specific reason to avoid the '05, unless the car has been parked in the garage for the last 12 years, and no recalls/maintenance have been performed on it. BTW, most recalls on the '05 were not '05 specific, but covered most if not all other years of the C6 run as well. In other words, by now, most '05s, will have had any problems already addressed.
As to which engine is better, snappier, I can say the LS3 definitely is. On the same car, the car will be faster, more responsive when accelerating, but will idle rougher, and is pickier about being stopped quickly, especially from high RPMs.
Adam Cifonelli's Avatar
Adam Cifonelli
I was in the situation when I was shopping around. I had to go with the LS3 Cause I'm the kind of person who every time I'd see an LS3 Id be like.. "I shoulda got that!". I went LS3.
Old Jul 10, 2017 | 10:03 PM
raspyc6's Avatar
raspyc6
had ported/polished IT and IM on both my LS motors, both LS2 and LS3 platforms are "bulletproof" to use the most common descriptor on here
Old Jul 13, 2017 | 01:20 PM
nick14003's Avatar
nick14003
I bought an 05, and I stand by what I said.
Old Jul 13, 2017 | 02:45 PM
Icecap's Avatar
Icecap
I have a 2007 3LT A6 convertible with the Z51 package and haven't compared it to an LS3 since I haven't driven or ridden in one but assure you it has excellent throttle response. I've had more than a few scary events where the back of the car tried to pass the front and haven't felt anything like that since I was into the muscle car scene of the late 60's and 70's.
One thing that really impressed me was that I found out that my rear axle ratio is 2.56 and from my past experience that ratio didn't belong in a performance car, I was wrong.
Another consideration about the LS2 if my research results were correct is that it is basically the LS6 engine that came in the C5 Z06 in 2001-2004. The LS2 has a compression ratio of 10.9 and the LS3 is 10.7 which is probably a bit more forgiving in the octane department, I run 94 in mine.
Old Jul 13, 2017 | 02:51 PM
RobLo's Avatar
RobLo
Care to expand on that comment a little, I have an '05 and I'm curious as to what your issue is with the '05, maybe I can learn something...
Old Jul 13, 2017 | 03:05 PM
owc6's Avatar
owc6
I put an LS3 into my '05, and I stand by what I said.
However I, too, am curious why you recommend staying away from an '05.
Old Jul 13, 2017 | 04:37 PM
Dutch08's Avatar
Dutch08
I'm currently in the market for a C6 corvette, and I'm doing some research. I know what the dyno numbers say power wise, but I'm wondering what one, if either is snappier. I...
I have an '05 (ls2) z51 manual, several people I know have 08+ (ls3) cars.
IMHO its the transmission.
My 05 is way "snappier" than any of their LS3 cars even with a Vitesse Controller. Seat of the pants they feel about as fast. My car is subjectively more instantaneous when press the throttle or shift. The LS3 automatics are easier (boring to me, but I don't need to hijack this thread with that war) to drive, more of a road GT car.
I'd try to drive both manual/auto and z51/non z51, as they have different gearing.
As for the '05, I don't have any problems with mine and I would not let that dissuade from a purchase.
Old Jul 13, 2017 | 04:46 PM
Racer1735's Avatar
Racer1735
I have an '05, Z51, manual. Before purchasing, I drove an '05 manual, '07 manual and an '08 auto. To me, the manual transmits the sense of power in a sharper (quicker) manner than what the A6 does. I was really thinking I'd go with the A6 when I started shopping around but to get the sense of power that a Corvette brings to the table, you really need the manual tranny.
Old Jul 13, 2017 | 08:44 PM
fourth vette's Avatar
fourth vette
Old Jul 13, 2017 | 10:43 PM
Dutch08's Avatar
Dutch08
enough said, drop the mic
Old Jul 13, 2017 | 10:59 PM
Adam Cifonelli
I dont know about "throttle response" but when people say LS2 and LS3 are pretty close and feel about the same. I took top 10 times of the LS2 and LS3 from the performance thread. Averaged out the top 10 1/4 times. Stock Results:
LS2 12.407
LS3 12.037
Thats a pretty big difference.
To LS2 vs LS3 throttle response
Old Jul 14, 2017 | 12:48 AM
Icecap's Avatar
Icecap
LS2 12.407
LS3 12.037
If you are into racing yes although you are talking 10th of a second. If you are just into driving and enjoying a fine performance car it doesn't matter jack shyte. These my dong is bigger than your dong memes start to get old quickly.
Old Jul 14, 2017 | 12:52 AM
Adam Cifonelli
If you are into performance .4 10ths of a second at 115mph is a slaughtering.
If you dont care about that sorta thing then its not a big deal. But for me..if I got the LS2 every time Id see an LS3 I'd kick myself in the butt. But that's just me.
Old Jul 14, 2017 | 07:47 AM
flyingbunnys's Avatar
flyingbunnys
LS2 12.407
LS3 12.037
Use the money saved by buying an LS2 and get headers, intake, and tune. That will make up that 4/10s of a second.
