LED's
Old Jul 31, 2017 | 11:58 PM
Got2rock's Avatar
Got2rock
Cruising
Default LED's
Hi I just installed some new LEDs in the front for my turn signal DRL they don't flash they just stay on what can I do to correct that problem
Old Aug 1, 2017 | 09:06 AM
bartsky's Avatar
bartsky
You need to splice in load resistors, and make sure bulb is installed right direction being LED.
Old Aug 1, 2017 | 09:46 AM
bassman50's Avatar
bassman50
Old Aug 1, 2017 | 03:01 PM
RC4G's Avatar
RC4G
Not having resistors will not stop the LED's from flashing, it will cause them to hyperflash.
First of all, you need to confirm the LED's are rated for greater than 14 volts. The first two sets that I originally received from a vendor were only rated to 13.5 volts and the charging system on my Grandsport was too much for them.
You should also try reversing the polarity on the LED's. Normally they will not light if reversed but it's worth testing.
Old Aug 1, 2017 | 05:08 PM
DOOKEY's Avatar
DOOKEY
Doesn't someone make an LED blinker relay by now?
Old Aug 1, 2017 | 06:56 PM
Got2rock's Avatar
Got2rock
Cruising
Hi,
The LED's are 12V & 3.5 W... The problem is that they Don't Flash they just stay On...
They sure look good though...
Old Aug 1, 2017 | 07:04 PM
bartsky's Avatar
bartsky
I installed these recently, and they work great...
http://www.ebay.com/itm/Switchback-3...53.m2749.l2649
Old Aug 1, 2017 | 07:14 PM
Got2rock's Avatar
Got2rock
Cruising
Hi,
Old Aug 2, 2017 | 11:51 AM
Hells's Avatar
Hells
St. Jude Donor '08
Hi,
Make sure you have the correct bulb. I bought some on ebay once that didn't work properly. It turned out they were 3157ck.
Old Aug 2, 2017 | 11:52 AM
RC4G's Avatar
RC4G
Hi,
LED's are rated for a range of input voltage, e.g. 12v - 18v.
There are cheap LED's that are only rated 12v - 13.5v and the C6 charging system consistently provides 14+ volts which fries the IC's in these lower quality LED lights.
Old Aug 2, 2017 | 11:54 AM
RC4G's Avatar
RC4G
Good call on possible bulbs designed for CK sockets.
Old Aug 2, 2017 | 01:53 PM
Spasetrucker's Avatar
Spasetrucker
Thanks for the info everyone. I am having this same problem with my 2002 Ford pickup. Now I have some knowledge to work with.
Old Aug 2, 2017 | 09:54 PM
Got2rock's Avatar
Got2rock
Cruising
Hi,
Thanks So Much, you were right, I just turned the bulbs 180 degrees & now my blinkers work & the hazard lights now flash again...
Thank Again,
AudrA
To LED's
