Need Help with driver door switches!
Ok guys 06 vert, I had the battery disconnected last night doing some under hood detailing. The top and both windows were down. When I connected the negative cable back.....nothing but head, tail and interior lights, would not do anything else! Yes the cable was tight.
Removed and reconnected the cable and everything seemed okay. Did not try the top or windows.
Went with my club on an trip today and realized the driver window switches, mirror controls, and lock switches don't work. Passenger door is fine, window works fine, from the passenger switch.
The power top will not work because I cannot index the windows.
Battery is less than a year old, no issue starting or charging.
Both FOBs work, and the learn process works. Alarm system ok.
The orange lock light on the dash is lit indacating service......
I have r&r the battery cable again for 30 minutes....no change.
I read an old post with this issue that was caused by a bad wire in the driver wire loom?
Ok let's share some knowledge ......PLEASE I'm stumped!
