Original plugs #
Old Aug 10, 2017 | 11:10 AM
jonnys07's Avatar
jonnys07
Default Original plugs #
I have a 2007 base convertible with 50K on it. I decided to change the original plugs and wires on it. I put in Delco wires and Iridium plugs #41-110 as called for as a direct replacement for the original plugs. You guessed it now I am getting a “Service Charging System” message. What was the original Delco Plug Number for this car? Yes, of course I tossed the original ones before getting the message. I am going to see if I can find a set and put them in to see if the message goes away.
Old Aug 10, 2017 | 11:50 AM
87SAM's Avatar
87SAM
If not done yet, I would double check that the plug wires are completely engaged on the plugs/coils. Should be a sort of double click.
Old Aug 10, 2017 | 11:53 AM
jonnys07's Avatar
jonnys07
Will do sir. Thanks, Jon.
Old Aug 10, 2017 | 01:26 PM
Bob Paris's Avatar
Bob Paris
If it's not that, you should go to a GM parts website where you can enter your VIN and then part #'s for your vehicle can be identified
Old Aug 10, 2017 | 01:51 PM
jonnys07's Avatar
jonnys07
Perfect. Thanks, Jon.
Old Aug 10, 2017 | 03:10 PM
Vet Interested's Avatar
Vet Interested
Old Aug 10, 2017 | 08:14 PM
SouthBaySurfer's Avatar
SouthBaySurfer
The plugs that came in your car were #41-985; they were discontinued several years ago. The replacement part number is 41-110.
Old Aug 11, 2017 | 10:04 AM
jonnys07's Avatar
jonnys07
Old Aug 11, 2017 | 12:14 PM
buckmeister2's Avatar
buckmeister2
You have the right plugs. I doubt if it is related to the message you are getting.
Old Aug 11, 2017 | 01:27 PM
jonnys07's Avatar
jonnys07
OK. Thanks, Jon
Old Aug 12, 2017 | 08:30 AM
Mad*Max's Avatar
Mad*Max
Old Aug 14, 2017 | 10:19 AM
jonnys07's Avatar
jonnys07
ok, thanks.
To Original plugs #
