It seems that some of the DIC controls on my 06 vert stick sometimes. I have to pull out by hand or continue to push until they pop out. Would appreciate any suggestions on how to alleviate this issue. It's not a big deal but it does get annoying.
Pull the bezel, pull the buttons and boards off the bezel via the back screws and clean them of the soda that someone got on the buttons to cause the problem in the first place.
Pods removed from the bezel, then apart to clean them.
Also to point out, if any of the bulbs are burnt out and need to be replaced, where is the new bulbs part number from radio shack you will need to solder in new replacement bulbs.
you still have to pull the bezel, then unscrew the bolts to pull the pods out of the Bezel either way,
Once you have it this far, then takes about a min to pull the pods apart to get the rubber front piece and boards out of them, then to just run all the parts except the circuit board under running tap water to flush the soda that was spilled on them away, a quick dry, and put the pods back together.
Hell, if the circuit board contacts need a quick cleaning, than that only take a second with some spray contact electrical cleaner instead.
2008 base...I had the same problem a few years ago so I got a can of electronic cleaner and a can of compresed air for cleaning my key board.I cleaned them without removing them and no problems since.I do blow out any dust with the canned air once in awhile,for some reason my gets a lot of dust inside?.....Only took about five minutes...Good Luck
Thanks this seems like a lot easier then pulling the entire dash. I'm not the most handy when it comes to these jobs
Thanks for your reply and advice. It looks like I would have to pull the dash to get to the bezel I'm not the handiest person and probably above my pay grade. I will try blowing out with compressed air as another member suggested.
