Yesterday I developed a clicking type noise while accelerating..it increases the more I give it gas..occasionally it will do it while idling or coasting.any ideas?
possibly lifter noise, but that usually goes away as the rpm's come up, in my experience. I would make a quick check of belts, pulleys, harmonic balancer, and exhaust fittings (possible exhaust leak?). Your friend said it is coming from the rear, but if it makes the noise while you are revving in park, it can't be back there, right? Have someone else rev it slowly while you look under the hood to see if you can locate the noise.
correct. There isn't any way for noise to be made in the rear unless it's an exhaust leak... I'm leaning towards lifter still, any chance you can record and post a quick video with someone slowly rev'ing the car?
I'm wondering if this could be the alternator going out..it's been acting crazy with voltage ranging from 14-11.5 and when I shut it down today it make a scrubbing type of a noise..
Easy way to check if your suspect the alternator, take the belt off and run it for a really brief moment and see if that ticking sound is still there. Cost nothing to verify and five minutes.
Well...now we have a front...rear...ticking...scrubbing sound?
If I knew what it was I wouldn't be asking..it's coming from the front and alt has been acting screwy but this noise just started Sunday..it's while driving idling parked but in varying degrees..
I KNOW this is an old thread but would you mine listening to my noise and telling me if its like the noise you were hearing?
