XM module AUX mod problems
This is all off the top of my head. I don't use the AUX input very often and the car is not with me right now or I would do out and verify.
You just need to select the XM Band and you should hear the music player that's now connected in place of the XM Tuner.
Did you take any pics of your install?
In simple terms, when you just tie the two separate sources, Aux and XM together, you are feeding the Aux source into the Head Unit/Radio/Nav and it is also feeding into the output of the XM Tuner.
You won't hurt anything, but the audio quality is compromised.
Now, whether you can actually hear any ill affects in the context of a Corvette's OEM audio system is entirely up to the individual listener.
And if you have just paralleled (Y'd) the Aux and XM together, then yes you need to find a way to "turn off" the sound coming from the XM Tuner and using channel 0 is probably the easiest option.
I used a standard 1/4" switching jack and plug (like a large headphone jack on your home stereo) to create my 'Aux In'.
The larger contacts/switches on the 1/4" jack are more robust and will last much longer than a typical 1/8" 'mini' jack will. And the larger plug handle let me incorporate the charging plug into the cable for my IPOD.
