question about window
Old Aug 23, 2017 | 06:02 PM
Testlightst's Avatar
Testlightst
6th Gear
Default question about window
So here is my first question to you guys.... The drivers side window has a " hard " close . When I've roll my windows up in the past in my other cars I just pull up the lever and it closes and the window stops on its on without any damage. On this car , I have 2 very small knicks in the edge of the window where it hits the inside framework so hard. Almost like it either needs some cushion or its not adjusted correctly to the right stop point. My first thought was to get some 3m adhesive back tape with a little padding and shove up in there. What are your thoughts?
Old Aug 23, 2017 | 06:07 PM
C6ToGo's Avatar
C6ToGo
C6 windows automatically drop a slight amount when you open the door and raise back up when you close.
Search "window indexing" if yours is not dropping. Easy and common fix.
Old Aug 23, 2017 | 06:36 PM
Testlightst
6th Gear
Its not the indexing that's the problem. Its does drop down like its suppose to do and raises up after door closes. Its when it raises up it seems like it goes too far in or too hard and causing small nicks on the edge of the glass.
Old Aug 23, 2017 | 06:49 PM
EVRose's Avatar
EVRose
Under the weather strip on the roof are 4 screws holding it on. Check that they are all screwed in tight. If one is loose it may be the window is hitting it.
Old Aug 23, 2017 | 08:22 PM
Testlightst
6th Gear
I will try that for sure tomorrow! Sounds like a good place to start. Thanks
Old Aug 24, 2017 | 02:45 PM
Testlightst
6th Gear
EVRose . One of those screws was loose . Thanks for the tip !!!
Old Aug 24, 2017 | 05:03 PM
EVRose's Avatar
EVRose
Glad I could help!
To question about window
