Memory seat problem
Old Sep 3, 2017 | 08:02 PM
hitekcm's Avatar
hitekcm
Default Memory seat problem
Guess I baffled the experts before since I got no replies.
Do you have to have power telescopic steering wheel option in order for memory seat to work?
I added memory drivers seat to my zr1 and cant seem to get it to function. I'm not getting any DTC's except for the telescopic steering option which I don't have apparently they are related I do know the wiring for that goes from the seat wiring to the steering cluster area and would go to the telescopic steering option if I had it..
My Tech 2 shows only a DTC for the steering not the seat memory???
I cant clear that DTC because its not there and the Tech 2 continues to check for it .
P.S. all set functions are working correctly, just no beep when memory buttons are pushed.
Old Sep 4, 2017 | 07:34 PM
TraceZ's Avatar
TraceZ
I was not aware you could get memory seats without the power telescopic wheel.
Is this something you are piecing together?
Old Sep 4, 2017 | 09:17 PM
hitekcm's Avatar
hitekcm
yes I added memory , heat and lumbar.
To Memory seat problem
