TPS sensor
Old Sep 5, 2017 | 05:46 PM
yellow2007's Avatar
yellow2007
Default TPS sensor
Tried searching here on this topic and couldn't locate what I needed. Can the TPS sensors be replaced without removing the tire from the wheel? I just had two new front tires installed and it took 2 guys, a tire machine a stick of dynamite and the jaws of life to get the tires off/on and I'd rather not go thru that experience again.
Old Sep 5, 2017 | 05:49 PM
Dragon Tamer's Avatar
Dragon Tamer
Yes. The tire just needs to have the bead broken from the rim. Sounds like you need to find another shop to do the work - with the proper tire equipment.
Old Sep 5, 2017 | 06:24 PM
yellow2007's Avatar
yellow2007
I agree. Had a nice tire alignment machine and I've known the owner for almost 20 years but I'm guessing run flats are a different kind of animal. I would do the sensors myself but since mine need to have that special tool and not just the magnet, I may try my local goodyear.....
Old Sep 5, 2017 | 06:29 PM
Dragon Tamer
I just had new run flats installed a month ago on my BMW. My guy has the "touchless" tire mounter, it took him roughly 15 minutes a wheel to dismount the existing tire and install the new one. With the proper equipment runflats are no more difficult that non-runflats according to him. I suggest looking for a shop that has roadforce equipment. Do you have a Discount Tire near you? They have the right equipment.
Old Sep 5, 2017 | 07:20 PM
yellow2007's Avatar
yellow2007
As a matter of fact I do. Maybe I'll check with them on the sensor install.
Old Sep 5, 2017 | 07:22 PM
Dragon Tamer
Yep - that's where I would go
Old Sep 6, 2017 | 06:02 PM
yellow2007's Avatar
yellow2007
Old Sep 7, 2017 | 12:12 PM
nick14003's Avatar
nick14003
If a tire shop was having problems, go somewhere else. I just changed all 4 tires and 1 new TPMS that went bad, they didn't give me even the slightest problem.
Old Sep 7, 2017 | 05:24 PM
yellow2007's Avatar
yellow2007
I believe you two are correct....Disappointing for sure. This guy has worked on all my cars for years including the 88 coupe.
To TPS sensor
