Headers and x install
Old Sep 9, 2017 | 04:19 PM
V3NOM's Avatar
V3NOM
Default Headers and x install
Has anyone had trouble installing TSP headers and x pipe I have the corsa sport axleback but seems like the x and axleback doesn't line up right unless I'm doing something wrong any help will be great thanks
Old Sep 9, 2017 | 06:31 PM
Not So Fast's Avatar
Not So Fast
I may be wrong but I think you are missing the Y pipe connector, You should have the headers connected to the X pipe and the X pipe connected to the Y pipe and in turn that connects to your over the axle exhaust, maybe this photo will help even thou it Kooks system
NSF
Old Sep 9, 2017 | 07:51 PM
jaybee924's Avatar
jaybee924
Did you order the right one? The correct years need or info and correct model? The LS2/LS3(08) 05-08 had a different angel axleback connector than the 09-13 LS3. Also are you an LS3 or a ZO6? If you ordered the Z06 (06-13) or ZR1(09-13) and your an LS3 that could be another problem also. I don't have headers but that's what I learned and I could be totally wong!!! LoL
Old Sep 9, 2017 | 08:21 PM
sabersaw30's Avatar
sabersaw30
I just put this settup on my car but i had the 3 inch corsa sports on my car. You should have some connector pipes in between xpipe and corsa settup. Mine went right in but real close to trans. Went and got the band clamps for mine the v bands would not work rite for me.
Old Sep 9, 2017 | 11:48 PM
V3NOM's Avatar
V3NOM
Mine is a base model but the axle back and the connectors from the x pipe don't line up for **** tried a lot of different ways and nothing seem to work
Old Sep 9, 2017 | 11:53 PM
V3NOM's Avatar
V3NOM
See those pipes don't match up at all
Old Sep 10, 2017 | 04:04 AM
Don-Vette's Avatar
Don-Vette
Looks like you just need to move it over a little and slide it in,length looks right. Make sure all bolts everywhere are loose first.
Old Sep 10, 2017 | 10:35 AM
V3NOM's Avatar
V3NOM
I'll try it again see if somehow I can slide in the axleback everything is still loose so I can have more play but damn never thought it would of been this much of a pain in the *** lol
Old Sep 10, 2017 | 11:06 AM
unclecookie's Avatar
unclecookie
NSF
Is that the system you installed in your car? Did you have any problems with a CEL before you had it tuned?
Old Sep 10, 2017 | 01:01 PM
sabersaw30's Avatar
sabersaw30
Might have to loosen up the pipes goin in mufflers and twist them over.
Old Sep 10, 2017 | 02:28 PM
sabersaw30's Avatar
sabersaw30
Deffinately sounds good base c6 through 3 inch corsas! Just got the tsp headers on mine!
Old Sep 10, 2017 | 05:31 PM
V3NOM's Avatar
V3NOM
https://youtu.be/q8Re1XaNRkQ
That does sound really good man. Did the axle back slide in good when u installed them?
Old Sep 10, 2017 | 05:34 PM
sabersaw30's Avatar
sabersaw30
I got my set used and had a zo6 settup on my car so i had to order the 3 inch connection pipes but the fit pretty good. But the 3 inch pipes were alot shorter than the 3 to 2.5 pipes like yours.
Old Sep 10, 2017 | 05:42 PM
sabersaw30's Avatar
sabersaw30
Its stormin outside cant get no good pics but as you can see alot shorter on my settup
Old Sep 10, 2017 | 05:54 PM
V3NOM's Avatar
V3NOM
Yeah mine are long and doesn't fit I tried all kinds of ways and nothing works so idk what else to do
Old Sep 10, 2017 | 06:15 PM
sabersaw30's Avatar
sabersaw30
Maybe somebody will chime in with corsa settup for 2.5 pipes.
Old Sep 10, 2017 | 06:44 PM
V3NOM's Avatar
V3NOM
Hopefully man I have a tune appointment on Wednesday so I'm hoping I'll be done with the car by then but that's the only thing holding me back from finishing
To Headers and x install
Old Sep 11, 2017 | 02:36 AM
V3NOM's Avatar
V3NOM
Update
this is the way I had to do mine I had to connect the axleback to the extensions first then slide them to the x pipe. Once that is done I had to slide the headers to the x pipe then bolt up the headers it was a pain in the *** so tomorrow I'm gna bolt up the mufflers hope they just slide in I'll see how it goes
Old Sep 11, 2017 | 03:56 AM
Don-Vette's Avatar
Don-Vette
Old Sep 11, 2017 | 05:21 PM
sabersaw30's Avatar
sabersaw30
Update
Thats great want to hear it after tune and keep me posted on dyno no. I still havent got mine tuned from swapping from zo6 to tsp settup. Made 417 with the zo6 settup.
