Ranger method for Brake fluid?
Old Sep 12, 2017 | 06:36 PM
zzjakect's Avatar
zzjakect
Default Ranger method for Brake fluid?
I recently discovered the Ranger method for my clutch fluid and was so happy with it I might have gone too far. I was checking fluid for a long trip to Colorado Through the New Mexico desert. I checked brake fluid and noticed it was kind of dark and old looking. Took my handy Battery water tool and sucked out brake fluid and replaced with clean DOT 3. New brakes are due after the trip, buy figured it couldn't hurt. I love clean fluids. I now do the clutch fluid like every two weeks. LOL.
Old Sep 12, 2017 | 06:49 PM
bartsky's Avatar
bartsky
I also do it on my brake fluid...
Old Sep 12, 2017 | 07:30 PM
SladeX's Avatar
SladeX
You are not alone.
Old Sep 12, 2017 | 08:30 PM
Oh Boy's Avatar
Oh Boy
Originally Posted by SladeX
You are not alone.
Don't waste your time. Brake fluid does not circulate like clutch fluid. The results will be minimal at best.
Old Sep 12, 2017 | 09:37 PM
Gman in NC's Avatar
Gman in NC
I've thought about this before. How does the fluid circulate in a clutch mechanism? It works pretty much the same way a brake system does.
Old Sep 12, 2017 | 11:06 PM
zzjakect's Avatar
zzjakect
Originally Posted by kecorrigan
Is it necessary or helpful to do it that often? I've done the ranger method once on mine with the clutch fluid maybe like 2 months ago, not sure when to do it again.
I do it when it looks dirty. It is so easy and cheap. Just like brake fluid. I swap some nasty stuff out and add some clean stuff. So....tell what that hurts?????
Old Sep 12, 2017 | 11:52 PM
FAUEE's Avatar
FAUEE
The correct way to do it would be to suck out the old dirty fluid, then bleed the brakes until clean brake fluid comes out. That's typically how I do my brake fluid changes.
Old Sep 13, 2017 | 12:32 AM
TomdaToolman's Avatar
TomdaToolman
Old Sep 13, 2017 | 06:56 AM
BlindSpot's Avatar
BlindSpot
Short answer is NO....
To Ranger method for Brake fluid?
