Some advice
Old Sep 13, 2017 | 11:15 AM
RickCC6's Avatar
RickCC6
Default Some advice
twice my 2013 M6 base model had really high coolant temps (240+) to where the a/c would stop blowing cold air, i checked the car and found the culprit. a plug that connects the fans was melted in the middle. plug has 3 wires. so what was happening was that it was not making a good connection and the fans were not turning on, causing coolant temps to go way up! cut off the plug, and hardwired it. and the car has been working fine now. 196 is the highest ill see it go before the fans drop it to 190. but i am very paranoid when i see it go above 196 lol.
my question is, what is the normal coolant temperature? before i had it hardwired i had seen 220 w/ a/c on in this hot texas weather (100 degrees). i just want some peace of mind and not be so paranoid the whole time and just monitoring coolant temp. it doesnt let me enjoy the ride as much. any advice would help, thanks in advance.
Old Sep 13, 2017 | 11:29 AM
Mike's LS3's Avatar
Mike's LS3
Just wondering it your car was every tuned. Normally, the maximum fan duty cycle is 90% which should not cause the plug to melt. However, some tuners set the duty cycle to 100% which may melt the plug.
Normal coolant temperature (with oem 187* T-stat) at highway speeds are 192-198*F. City driving or stuck in traffic 198- 220*+F depending on the air temperature. Even with 100* weather, ECT at 220* is normal in the city.
The stock fan setting 15% at 199*F and gradually increases with higher temps peaks at 90% once temps reach 224*F.
A/C on temps will run a little higher and the fan will increase speed as A/C pressure increases, but still maxes at 90%.
Old Sep 13, 2017 | 11:57 AM
RickCC6's Avatar
RickCC6
as far as i know, it isn't tuned. but im gonna take it to a local tuner here to check it though. thanks for the help! really appreciate it.
Old Sep 14, 2017 | 12:56 PM
Landru's Avatar
Landru
Why?
A burned fan connector causing overheating/high op temp isn't really rare, especially Corvettes driven in sunbelt states. Reported 3-6 times a year.
Found/fixed issue when connector was replaced & everything's fine, now.
Just like before overheating?
Old Sep 14, 2017 | 01:07 PM
wayback's Avatar
wayback
Common issue for the C6.
I see 194 to 200 on hwy here in N. Texas.
200 to 230 stuck in traffic.
On my 85 C4 the fans were programed to come on at 240 from the factory.
Old Sep 14, 2017 | 02:54 PM
RickCC6's Avatar
RickCC6
Originally Posted by Landru
Why?
yea, now that i think about it and read previous threads and saw comments on here its pretty normal. i have them hard wired for now, do you guys recommend just getting a new plug? or soldering them and keep it as is? also would anybody happen to know the part number for that plug? thanks in advance
Old Sep 15, 2017 | 11:17 AM
Landru's Avatar
Landru
You found the issue before knowing it's relatively common. Good on you, only wondered why the extra expense of a tuner to check what's always worked. Good to see you've come around.
IIRC for those w/ this issue some soldered, some replaced connector.
The whys theirs so six of one half dozen the other.
Gene Cully @ Cultrag is a forum sponsor & go-to guy for most C6 parts. https://www.cultragfactoryparts.com/
Gene c/would provide correct connector should you decide to remain OEM.
Soldering becomes an issue if work's routinely done requiring fan/radiator removal.
Doesn't sound like you mess around there, so pick your poison.
Old Sep 15, 2017 | 10:18 PM
Not So Fast's Avatar
Not So Fast
For a future fix can anyone show or tell where this plug is
NSF
Old Sep 16, 2017 | 11:24 AM
RickCC6's Avatar
RickCC6
NSF
ill upload some pics in a sec, although you wont be able to tell where exactly its located in those pics. but the best i could describe it is behind the radiator, infront of motor.
Old Sep 16, 2017 | 05:51 PM
BlindSpot's Avatar
BlindSpot
NSF
Bobby - the connector subject to melting is attached to the plastic fan shroud. It is a 3 wire plug, two huge (8/10) gauge wires (black and red) and a smaller red 18 ga signal wire. you really need to look underneath, behind the radiator at the plastic fan shroud. You'll see the connector on the passenger's side. The connector can look normal and will not reveal a burnt connection until you unplug it.
Here are two pics from mine, looking straight up you can see the bottom of the supercharger so it'll orient you where to look.
Old Sep 16, 2017 | 06:27 PM
Not So Fast
Yep, I see it Steveo, in spite of that Heimholtz Air Box or whatever it called, damned thing is always in the way.
But as you said it looks pretty cherry from what I can see so I'll save the info just in case, thanks
To Some advice
