Upgrades to base corvette that make sense
2nd Gear
In my corvette journey, I started with a base car, graduated to a Z06 and am now back in a base model. I was not fond of buying $2K of tires every 15000 miles on the Z06 is why I downgraded. But I sorely miss the power of the Z06. Are there any upgrades to the power of the base model cars that are cost effective and do not harm anything else on the car? I am not looking to make it into a Z06. I just wish it ran a little stronger.
Retired & lovin' it!
SeeMeGo (09-14-2017)
Along with the above stated you can also go with a custom Cam for you Vette -
I would suggest a PatG cam
https://www.guerragroup.com/camshaft-help
If you are a A6 and have 2.56 gears you could do a 3200+ stall and a 3.42 Z06 rear (direct bolt in)
And of course a Dyno tune will be necessary -
Thanks,Matt
Thanks,Matt
I would suggest you fill in your bio with your location. That way, people in your area can recommend a good shop to check out. Maybe even someone in your area has had some work done, and can give you their experience.
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
Altho generic advice is adequate (and good of those to make these observations), I have to agree w. Buck. Wouldn't you rather have a bit more info maybe even specific to your area?
IMO the answer is no....not cost effective for horsepower gains to get near Z06 levels.
Your easy options are headers, cats, x-pipe, mufflers, cold air intake, throttle body mod, blueprinted intake manifold and a tune.
Cost?
My estimate $5000.
Horsepower increase?
My guess forty.
Next level, camshaft with the above mods.
Cost?
Another $1500 installed.
Additional HP twenty.
Then you could consider gearing and the throttle controller.
Those would fool the mind making the car feel faster.
Lastly you have a Nitrous (best bang for the buck...some say).
Or a Supercharger (again not cost effective) and you have your original tire wear complaint.
Good luck in your decision.
Cost?
My estimate $5000.
My guess forty.
Cost?
DoubleP (09-14-2017)
The proper Cam will yield results much better than 20 HP, as proven many times over.
But as stated you really won't be able to reach Z06 level until you get into H/C and LT's and Dyno tune -
OP - do you have a MN6 or A6 transmission?
Thanks,MAtt
Thanks,MAtt
As mentioned above, if you built your base to near ZO6 power levels, wouldn't go through tires just as fast the ZO6?
I suppose base size tires are cheaper than though.
Just to add.
Tire wear has a lot to do with HP, driving habits and tire quality. Add more HP and you will need stickier tires, especially on a base which has a narrower tire (285).
Add your choice of mods: Headers, CAI, cam, tune, gears, stall (auto), nitrous or S.C. and yes, stickier tires and it all adds up $$$. Maybe the extra set or two of tires for the Z06 is not so expensive now.
Personally, I would of kept the Z06 and addressed the valve issue (if not done already) and be done. But that's just me.
I'm not seeing the logic here, unless you limited your mods to headers, cai and tune.
Having your Alignment done according to the PFADT specs would have allowed you to have normal tire wear and your shoes would have had a long life run...
Sorry if you are just hearing about this now....
Cam and Install $2000
LT Headers $400
CAI $200 used
E85 Pin and Sensor $100
Probably close to 3k with header labor- Done and Done!!
500 wheel HP and 450ish TQ - On a LS3 Motor
LT Headers $400
CAI $200 used
Received 2,683 Likes
2018 C6 of Year Finalist
Get a supercharger, CAI, exhaust, tune, and call it done.
St. Jude Donor '15
CAI, long tube headers, exhaust, tune, and Vitesse Throttle controller.
I'm betting it will sound awesome and a lot more fun after that....then you can decide if you want to take it further after that.
Z51 sway bars and Z06 shocks are also a cheap way to make it handle way better if you're planning to do any cornering ever
Except from what I understand, drop the CAI for a loss of maybe 10 hp.
LTH: 30-40ish
Cam: ??? depends how wild you get
but people have been posting dynos nearing the 500whp with those two mods. I'd be happy with 450 and a daily driveable cam.
