E-30 in ls3
Old Sep 15, 2017 | 04:40 PM
handyandy1496's Avatar
handyandy1496
Default E-30 in ls3
Local speedway gas station has E-30. can it be used without tuning or using a flex fuel kit in ls2's and ls3's ? Any advantages? Disadvantages?
Old Sep 15, 2017 | 05:39 PM
Red Devil Z51's Avatar
Red Devil Z51
I wouldn't try it in my car
Old Sep 15, 2017 | 06:26 PM
sjw91's Avatar
sjw91
Don't try it. Page 5-6 of my 2008 owners manual says not to use higher than E10.
My Lexus can use up to E15, so I tried it once. Gas mileage dropped 2 mpg, and it seemed a little less responsive. Not worth the 5 cents per gallon savings, in my opinion.
Old Sep 15, 2017 | 10:53 PM
jrose7004's Avatar
jrose7004
I don't even put E10 in mine.
Old Sep 15, 2017 | 11:12 PM
Red Devil Z51
you got that **** right jim
Old Sep 16, 2017 | 06:12 AM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Don't do it.
Old Sep 16, 2017 | 08:34 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
ANY ethanol will lower mileage. Chemically it should lower by about half the concentration. 10% ethanol should lower mpg 5% but my experience is 10% lowers much closer to 10%. That is why high ethanol concentration gas is usually a lot cheaper than real gas except where the stations are trying to scam the ignorant customers or recover the higher cost of ethanol where the government doesn't subsidize it as much.
Next it will damage the fuel system http://www.popularmechanics.com/cars...damage-engine/ Maybe that's why your owners manual says DON'T DO IT!!! DUH!!!
Old Sep 16, 2017 | 09:36 AM
sjw91's Avatar
sjw91
My numbers agree with yours. The CT usually gets 43 mpg, the extra 5% ethanol lowered the mileage another 5%.
On the other hand, our vans at work are flex-fuel and run on E85. They actually drive really well and average about 17mpg in the city. I don't know what a gas version of a Caravan normally gets, but I wouldn't expect more than 20.
To E-30 in ls3
